10-May-2017, 01:08 PM
Hey dudes and dudettes,
I am a bit uncertain about the whole parallel charging. The main question is, if your batterys are not discharged to the same voltage level... let's say one battery is at 14.0V and the other one at 14.8V, I would think that I could just put them together on a parallel charging board so they can balance eachother out. Let's say they stay like this for 10 minutes. Then I could plug the board into a charger and charge them together.
Is my thought correct? The only thing I could think of that would be a danger would be a too high current between the two batterys, but shouldn't that only be a problem if one is discharged to 14V and the other one is completely charge to 16.8V?
What are your thoughts and expiriences on that?
Because it would be great if I just flew one pack *stick it on the board* next pack *stick it on the board* next pack *stick it on the board until I have 4-6 and then charge them all together
I like turtles
