PPM Flysky Betaflight FAILSAFE
PPM failsafe question:
I bought this receiver, no problem with it. But it is PPM so for Flysky in AHFDS there's = no RX-Failsafe.
You have Failsafe TX-RX options only with AFHDS ( A ).
I'm trying to setup a Betaflight 2.0 failsafe, but, turning my TX off doesn't trigger the Betaflight failsafe at all, I tried many possibilities. Any ideas ?
http://www.gearbest.com/multi-rotor-part...92846.html
More than 3 people i know complained about PPM on Flysky doesn't work... and we have yet to find a solution..
sorry i am a Frsky guy.. never used Flysky.
  Betaflight Github questions Rob Axel 6 196 13-Feb-2024, 11:40 AM
  betaflight config 10.10 RC2 issue Rob Axel 3 227 10-Feb-2024, 01:21 PM
  Betaflight Motor Test Results in SmokeStopper overvoltage LoganFPV 5 234 01-Aug-2023, 11:22 AM
  Build T-Motor F7 stack - Betaflight Gyro update frequency 3.2kHz ???? MindBenderFPV 2 3,082 18-Jun-2022, 09:10 AM
  Solved Betaflight 4.3.0 RC3 SoCal_FPV 5 527 17-Feb-2022, 06:30 PM
Last Post: SoCal_FPV
