15-Jan-2019, 05:05 PM
Having a bit of problem and looking for any suggestion on how fix.
Trying to build up my second quad and getting power loss on all motors over 1/3 of max throttle. In betaflight when I test the motors everything works fine until I get to over 1/3 of max throttle then they all cut out. Noticed that the voltage readings in betaflight is ok up the 1/3 point then it drops quickly. When I decrease throttle, the voltage reading increases and motors work again to the 1/3 level. Have tried different batteries to no avail.
Not sure what the issue may be and really appreciate any suggestion on possible solutions.
Updated FC firmware and ESC's BLHeli32 to latest versions.
FC - CL Racing F4S
ESCs - DYS Aris 35A
Motors - Emax 2205 2600kv
Batteries - Tattu R-Line 1550 mah 75C
FC - CL Racing F4S
ESCs - DYS Aris 35A
