Help!
First, sorry if this question was already posted and I'm repeating it, but I did not find anything simmilar in this forum (nor in other forums and, generally, online) to my problems listed here. So I'm posting it and hope some of you PID gurus here can help me to solve it.
I fly only brushed micros, FPV. Mostly indoors (outdoors only in the backyard and when there is no wind and rarely). I fly tiny whoop clones I made out of different toy quad "Silverware" compatible boards and frames like Boldclash BWHOOP and Eachine E011. They all are flashed with Silverware - open source firmware with acro mode set. I used to fly in level mode, but I switched to acro before few months so I am still new in acro - but just few months of practice cause me to get into it rather OK (at least I think ). Still can't do flips nor rolls I but I can fly around rather fine and stable with some of my 6mm builds - but with some (7mm), I have lot of problems tuning them.
I read and watched lot of PID tuning videos and I think I am starting to get feeling how it should be done and how quad behavior needs to "feel" during tuning and after success, but I still strugle with some specific problems. And what I simply can't find anywhere is relating some specific behaviours of quad with PIDs - to be precise, what behaviour is caused by what PID and/or PID combinations and what to increase/descrease to fix it. Because, simple fast left/right moves and reducing oscilations by tunning PIDs + other standard and usual methods of tuning are OK but does not solve all specific problems I have on some 7mm builds (6mm builds are mostly OK with little modified stock PIDs from fimrware so I fly them more than problematic 7mm which I can't "tame").
And here is list of these problems on my 7mm buids (behaviour during indoor flying with stock PIDs from firmware):
Now, would be great if somebody help me with relating these problems with PID and help me to finally set it up and fly and not tweak constantly (which started to be very frustrating because lately I just started to randomly put numbers here and there becasue I don't know what to do any more - and without success ).
Thanks in advance.
- In hovering quad sometimes yaws by itself. Sometimes roteates to the right, and sometimes to the left. My TX (deviated Devo 7e) has deadband set on all channels and channel monitor says 0 during yawing so it is not related to sticks nor calibration of TX (also some quads does not yaw with the same TX - so it is definitelly not due to TX)
- In hovering sometimes it drifts randomly to all sides (goes everywhere by itself - little to the left, then start to go right, then back, forward... like floating on a water but without wobbling and without oscilations - it just glide around by itself a lot more than it is normal and sometimes "bounces" like it hit some invisible wall during hovering - all that needs a lot of stick moves to hold it at one spot)
- In hovering sometimes it increases/reduces throttle by itself (this is rare but happens sometimes - like I pushed/pulled throttle but I did not touch it)
- No "locked in" feeling during flight - while flying straight, it sometimes drifts to a side (not yawing - straight drifting to a side) and when I try to get it back on track, it start to go "everywhere" (like a "drunk" - it is not wobble nor oscilations - flying it feels like figthing a ship on waves - hard to stabilize it and get it back to track)
- No "locked in" feeling during normal turns - like that yaw drift from hovering hits here too - also, when turning, it starts to go "everywhere" after turn is done
- In fast turns (180 degree turns and braking that way) it wobble 1-2 maybe 3 times when turn is over and, also, tend to go "everywhere" after turn is done.
Thanks in advance.
