Pitch with a KK2 board
Hi guys,
I`m building a quadcopter with a KK2 controller board. However, I use the tilting of the rotors to yaw the drone and that works fine. Then, I wanted to replace the functionality of traditional pitching with rotating all rotors either to the front or the back to move forward or backward. Unfortunately, that didn`t quite work as imagined and I`m not quite sure why. Could it be that when the board receives a signal on the pitch channel it expects the craft not to accelerate forward or backward but to move around the pitch axis and when the sensors don`t detect such a movement (because pitch is replaced by tilting rotors) the board somehow tries to correct it and the craft gets out of control ?
If so, has any of you guys an idea how I could solve this problem ?
I thought maybe I could use the aux channel as an additional channel to implement the forward/backward movement through tilting the rotors. Is that possible ?
Thanks for your help!
I hope someone can answer your question. But this FC goes way back. I know some of the members here were not even born when this was around. Smile
(03-Apr-2020, 09:55 PM)voodoo614 Wrote: I hope someone can answer your question. But this FC goes way back. I know some of the members here were not even born when this was around. Smile
Which one would you recommend ?  Smile
It depends on what you to do? I am not sure of your objectives.
Just build a fixed frame quadcopter to fly fpv like what you see on YouTube?
Do you want a tilt frame quadcopter?
What purpose is this quad for?
(03-Apr-2020, 10:08 PM)voodoo614 Wrote: It depends on what you to do? I am not sure of your objectives.
The goal is to build a VTOL airplane. That`s why I don`t want to pitch to move forward but tilt the rotors. Yaw is realized through tilting rotors as well, roll works just like with a quadcopter.
It looks like you do have the correct FC. I assume you loaded the VTOL custom firmware. I probably recommend you ask your questions at the link below. Most members here are not familiar with this type of setup.
https://www.rcgroups.com/forums/showthre...for-VTOLs)
  Pitch Axis faster Roll Axis - Same Rates omtb1985 6 249 13-Apr-2024, 08:07 PM
Last Post: omtb1985
  Board sizes and FPV frames aeku 32 872 27-Oct-2023, 07:48 PM
Last Post: voodoo614
  Weird motor noises on yar/pitch/roll [email protected] 16 1,084 17-Sep-2023, 02:25 PM
Last Post: [email protected]
  Invert Pitch- Radiomaster Zorro FPVme 6 1,933 23-Apr-2023, 03:40 AM
  Low pitch buzzing from motors Kanez 2 214 26-Mar-2023, 09:13 PM
Last Post: Kanez
