02-Feb-2017, 02:36 AM
My 130 build with the Furious Piko Blx flight controller went well with the Fr Sky X4r receiver.....s bus
After 3 flights, the Piko board dropped to 2 volts out put. The Fr Sky rx dropped out as it needs 5 volts.
I found out, after much web searching, that others have had similar problems with the Piko Blx board 5v regulator or worse.....DOA.
I ordered another Piko board , hoping to get a "good one" this time.
I moved all the wiring over to the new board, which came pre flashed with the latest Betaflight.
The FC does not recognize the Fr Sky X4r. In Beta flight "motors" page , the motors do turn up and in the right direction.
But, tx switches and any tx stick inputs don't show up.
I was successful with the Piko Blx board the first time before the 5v regulator took a poop.
Any ideas?
Any ideas?
