Hi all.
Hope I put all this right so I can get some help. Any help would be grateful. and sorry if this is wrong.
Build;
Gravity 280
20A little bee's esc - newest filmware
HellFire 2206 2300KV
DAL 5045BN
SP-Racing F3 - Betaflight newest filmware 2.6.0
Also loop time was set to 500.
BB Logging
I can add a Video too if that would help I just seem to get worse not better and any help in the right direction would be much appreciated
Build;
Gravity 280
DAL 5045BN
BB Logging
# dump
# BetaFlight/SPRACINGF3 2.6.0 Mar 31 2016 / 23:01:30 (24b97ae)
# dump master
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -ONESHOT125
feature -BLACKBOX
feature VBAT
feature RX_SERIAL
feature FAILSAFE
feature RSSI_ADC
feature ONESHOT125
feature BLACKBOX
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
map TAER1234
led 0 15,15:ES:IA:0
led 1 15,8:E:WF:0
led 2 15,7:E:WF:0
led 3 15,0:NE:IA:0
led 4 8,0:N:F:0
led 5 7,0:N:F:0
led 6 0,0:NW:IA:0
led 7 0,7:W:WF:0
led 8 0,8:W:WF:0
led 9 0,15:SW:IA:0
led 10 7,15:S:WF:0
led 11 8,15:S:WF:0
led 12 7,7:U:WF:0
led 13 8,7:U:WF:0
led 14 7,8:D:WF:0
led 15 8,8:D:WF:0
led 16 8,9::R:3
led 17 9,10::R:3
led 18 10,11::R:3
led 19 10,12::R:3
led 20 9,13::R:3
led 21 8,14::R:3
led 22 7,14::R:3
led 23 6,13::R:3
led 24 5,12::R:3
led 25 5,11::R:3
led 26 6,10::R:3
led 27 7,9::R:3
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
aux 0 0 1 1200 2100
aux 1 2 0 1875 2100
aux 2 27 0 1400 1600
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
set min_check = 1040
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rssi_ppm_invert = OFF
set rc_smoothing = OFF
set max_aux_channels = 6
set debug_mode = NONE
set min_throttle = 1025
set max_throttle = 2000
set servo_center_pulse = 1500
set use_oneshot42 = OFF
set use_multishot = OFF
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set disarm_kill_switch = ON
set small_angle = 25
set fixedwing_althold_dir = 1
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set serialrx_provider = SBUS
set sbus_inversion = ON
set spektrum_sat_bind = 0
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_default_lattitude = 0.000
set frsky_default_longitude = 0.000
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set battery_capacity = 0
set vbat_scale = 110
set vbat_hysteresis = 1
set vbat_pid_compensation = OFF
set current_meter_scale = 400
set current_meter_offset = 0
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = -90
set gyro_lpf = OFF
set gyro_sync_denom = 4
set gyro_lowpass_hz = 80.000
set moron_threshold = 32
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set yaw_control_direction = 1
set yaw_motor_direction = 1
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set super_expo_factor = 30
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = OFF
set gimbal_mode = NORMAL
set acc_hardware = AUTO
set acc_lpf_hz = 10.000
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set acc_trim_pitch = 0
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf = 0.600
set baro_cf_vel = 0.985
set baro_cf_alt = 0.965
set baro_hardware = AUTO
set mag_hardware = AUTO
set mag_declination = 0
set pid_process_denom = 1
set blackbox_rate_num = 1
set blackbox_rate_denom = 2
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
# rxfail
rxfail 3 a
rxfail 5 h
# profile
############################# PROFILE VALUES ####################################
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set yaw_p_limit = 400
set pid_delta_method = MEASUREMENT
set dterm_lowpass_hz = 70.000
set dterm_average_count = 4
set iterm_reset_degrees = 200
set yaw_iterm_reset_degrees = 50
set yaw_lowpass_hz = 70.000
set pid_controller = LUX
set p_pitch = 35
set i_pitch = 30
set d_pitch = 45
set p_roll = 31
set i_roll = 20
set d_roll = 40
set p_yaw = 95
set i_yaw = 50
set d_yaw = 0
set sensitivity_horizon = 75
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 0
# rateprofile
set rc_rate = 100
set rc_expo = 60
set rc_yaw_expo = 20
set thr_mid = 50
set thr_expo = 0
set roll_rate = 75
set pitch_rate = 65
set yaw_rate = 50
set tpa_rate = 0
set tpa_breakpoint = 1500
