Over-propping DYS BL 20a?
I've got DYS Bl20 ESCs paired with Multistar V-Spec 2205 2300kv. With KingKong 5040 (two blades) all motors pull ~60amps on the ground (measured with a clampmeter), now I've ordered KingKong 5040x3 and I'm wondering if the ESCs can take it. Thanks!
Build - Fly - Crash - Repeat
Full throttle while holding the quad down? If so, this will be static thrust and it will not draw that much while in the air. I fly with kingkong 5045 3 blade on 20 amp escs without any problems. The max current I get whit those in the air is about 70 amps, and those props are heavier than the 5040 tris
(30-Sep-2016, 10:35 AM)oyvinla Wrote: Full throttle while holding the quad down?
Yes.
Thank you very muchSmile.
i fly daily on 20 A esc, and use 5045 HBN from DAL... no burners yet
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
Yea i use 5045BN on my 20A ESC with 2300kv cobra Smile
yup cobras... forgot to add, those are triblades... so not that easy to kill the hardware
All the best
  HV 4S on iflight SucceX-D 20A Whoop F4 AIO Board dwije21 1 164 02-Aug-2023, 09:13 PM
Last Post: Lemonyleprosy
  DYS BE1806 2300KV brushless motors coyote_dc5 2 453 08-Oct-2020, 08:06 PM
  DYS Aria 35A ESC with broken LED...toast? Jonathan ott 1 367 01-May-2020, 04:18 PM
Big Grin Melted a DYS Shu motor today! Drone0fPrey 5 886 18-Mar-2020, 11:53 PM
Last Post: Drone0fPrey
  Help DYS 1104 7000KV - Is my motor Burnt? Can it be rewind? sim_tcr 11 1,261 12-Dec-2019, 11:48 AM
