Threads: 593
Likes Received: 9,027 in 6,681 posts
Likes Given: 1,428
794 Have you wired the camera through the FC?
Make sure you have the video format specifically set to either NTSC or PAL to match the format that your camera is outputting (don't use the AUTO setting). That setting can be found in the top right on the OSD tab in Betaflight Configurator.
Threads: 1
Likes Received: 0 in 0 posts
0 yes.i've already try it with NTSC or PAL.
i will check it again about the wire.thanks
Threads: 593
Likes Given: 1,428
794 What goggles are you using? Do they automatically detect the PAL or NTSC format, or do you have to switch them manually? If they are automatic then unplug the power from the goggles and the quad, then power up the quad first and wait for the VTX to fully initialise (10-20 seconds should be enough), then power on the goggles after that, in that order, and see if you then get any OSD data.
