Osd help
I have the NANO F3 FLIGHT CONTROLLER WITH OSD AND BEC from Airblade. It works fine,but, the osd is set up on Betaflight, so I set the osd to show mah value and it does show up on the osd display but it stays at 0 value. The voltage and time elapsed does work but not the mah.
Any idea what I am missing or do you think this osd doesn't do mah?
Thanks for your knowlege and time.
Willie B
Is the mah in the OSD flashing 0? What is the voltage reading within BF configurator?
The trees are all out to get me
Thingiverse
YouTube
Do you mean this board?
[Image: GSxZlffl.png]
If so, which target is it flashed with? Have you enabled the current meter feature in the configurator? How have you connected your battery to the board? Are you connecting all the ESCs to the power pads on the board?
I come to find out that this particular fc ( not the one pictured) does not support mah or current . Pooh. Is there a 20x20 mounting mini fc that does have mah reading?
Thanks for responding.
The one I posted a picture of?
The fc I bought does not support mah or current draw. The one you pictured I don't know what it does. Does it have a current sensor on it? If so, it should show MAH function. Let me know.
(24-May-2017, 12:35 AM)CaCondor Wrote: The fc I bought does not support mah or current draw. The one you pictured I don't know what it does. Does it have a current sensor on it? If so, it should show MAH function. Let me know.
Yes!
The flight controller pictured is the Omnibus AIO F3 Nano which is here at Airblade UAV.
It has a current sensor.
And you can clearly see the current sensing circuitry on the photo.
(24-May-2017, 06:31 AM)unseen Wrote: Yes!
Thanks for clearing that up. Looks like it's the one I have needed all along.
  Osd help jgriz99 15 1,040 15-Apr-2024, 10:41 PM
  No OSD, Converted analog to HDZero Quads FPVme 14 249 24-Mar-2024, 08:35 PM
  Voltage in OSD flashing 0.0V Mpvisuals 11 5,624 23-Mar-2024, 06:51 AM
Last Post: nikhilfpv
  Another black screen with OSD przemczan 17 5,616 06-Mar-2024, 09:32 PM
Last Post: Dexter
  Help, my OSD doesn't jive with the elements in the BF preview (DJI) paddle2thesea 2 149 01-Mar-2024, 12:53 AM
Last Post: paddle2thesea
