Threads: 84
Likes Received: 8 in 8 posts
Likes Given: 232
0 I have runcam wasp
and goggle v 2 dji
and I enabled MSP + display in the port,
BF
and the osd tab the elements its ok
but it still does not show me the elements in the screen goggle
Threads: 582
Likes Received: 8,930 in 6,606 posts
Likes Given: 1,425
786 Does the Air Unit come out of low power mode when you arm the quad? If not then it means that the MSP connection between the FC and Air Unit isn't working properly. Check the physical wiring.
Threads: 582
Likes Given: 1,425
786 Arm the quad (with props removed) and check to see if the low power mode warning in the bottom right hand side of the goggles OSD disappears.
