Threads: 81
Likes Received: 14 in 9 posts
Likes Given: 17
1 For Christmas I upgraded my from 01 system to 03 and I am not that impressed. I was just wondering what other people thought? One of my biggest problems with the new system is the 03 Air Unit gets way too hot. I do live in Phoenix and for 6+ months out of the year it is over 90 degrees 24 hours a day. I have overheated my AU once and now I do not fly if it is over 90. Luckily I kept my original setup and fly it in the hot weather. I really do not see that much improvement over the original. Any thoughts???
Threads: 60
Likes Received: 1,000 in 726 posts
Likes Given: 96
51 I picked up an O3 unit to try, but after a few test flights its been pretty much sitting on the shelf. Some people love the O3, so I guess it will depend on your use case. For me the minuses, noticable latency at anything below 100fps, poor low light/back light imaging, fussy mounting to get props out of view and clean gyro, weight, and cost. The fpv image is prettier in the right lighting (and probably even better if you have the OLED 1080p goggles), better range/penetration, and the recorded 4k image is very nice quality and if you have it mounted well you get smooth stabilized footage, but much more flexibility using a Naked Gopro. I don't fly in hot enough weather to notice any overheating though.
Threads: 81
Likes Given: 17
1 Well, as for the range issue??? I do not see any difference. I fly pretty much the same routes with both systems and lose bars at the same distance. Maybe I don't push my system as far as other people, but for me range was never the issue. I kind of want to sell my system but know I cannot get close out of it as I put into it??? I would gladly get some V1 AU's and maybe some V2 goggles just again. As I said, the AU get's really hot here in Phoenix and that puts a damper on using it 6 months out of the year :-(
