29-Sep-2021, 01:47 AM
Hello.. I've had my radiomaster tx12 connected to opentx companion before... for some reason it won't connect anymore...i put it in bootloader mode it shows usb connected for about a second when usb connected then goes back onto write firmware screen and on companion it says no radio found if i select read firmware or anything... do i need to use the exact usb type c cable that come with it or will any usb data cable work.. i accidently deleted all sd card contents so its blank... I'm on 2.3.11 firmware and bootloader on radio... the companion in trying to use is 2.3.14... any help would be appreciated
