19-Jan-2023, 11:37 PM
I wonder has anybody heard or used CHATGPT it's an open source for now, chat based ai program hosted on the internet, trained up until 2021.
You can ask it about most subject's, legal and moral, it can write scripts in any language the other day one of our engineers asked it to help with writing a PID script in python to control temperature it returned this.
So i asked it to tell me how to install betaflight on a F722 it said
I know this is not really FPV related but I thought maybe some people here might also find a use for it, here's the link
ChatGpt
you do need to register an email, But try it out it's free with no adds, I have nothing to do with this project but I'm using it more and more everyday, and so are the people around me.
Quote:Code:import time
# Set the desired temperature
desired_temp = 25
# Get the current temperature
def get_temp():
# Replace this with code to read the current temperature from a sensor
return 25
# Control loop
while True:
current_temp = get_temp()
# Check if the temperature is too high
if current_temp > desired_temp:
# Turn on the cooling system
print("Turning on cooling...")
else:
# Turn off the cooling system
print("Turning off cooling...")
# Wait for a bit before checking the temperature again
time.sleep(1)
Which i was told would work
Quote:To flash a MAMBA Basic F722 Mini with Betaflight, you will need to follow these steps:You can all say if this is wrong here, but it looks ok to me at first glance.
It's recommended to back up your current configuration before flashing and also to check the Betaflight documentation for any specific instructions for your flight controller.
- Download and install the latest version of the Betaflight Configurator onto your computer.
- Connect your flight controller to your computer using a USB cable.
- Open the Betaflight Configurator and click on the "Connect" button to establish a connection with your flight controller.
- Once connected, click on the "Firmware Flasher" tab.
- In the "Firmware Flasher" tab, select the latest version of Betaflight firmware for your flight controller from the drop-down menu.
- Click on the "Flash Firmware" button to begin the flashing process.
- Wait for the process to complete and then disconnect your flight controller from your computer.
- Power on your flight controller and verify that the new firmware is installed and running correctly.
ChatGpt
