03-Feb-2016, 08:43 PM
When lowering the throttle to 0 I have one motor that will instantly stop well the other three motors seem to free wheel for a second. Any ideas what could be causing this?
One motor stopping first |
03-Feb-2016, 08:43 PM When lowering the throttle to 0 I have one motor that will instantly stop well the other three motors seem to free wheel for a second. Any ideas what could be causing this? 03-Feb-2016, 10:08 PM (03-Feb-2016, 08:43 PM)WobieWon Wrote: When lowering the throttle to 0 I have one motor that will instantly stop well the other three motors seem to free wheel for a second. Any ideas what could be causing this? Are your ESC's Blheli and Oneshot capable? If so Check in Blhelisuite and check that all the esc's are running the same on motor timing etc. Sounds to me like only one esc has active braking on. Also while in Blhelisuite just check that all the esc's are running around the same Min and max on Throttle. IE: my min is roughly 1028 and max is 1970, you can manually change the settings and save. |
Betaflight Motor Test Results in SmokeStopper overvoltage | LoganFPV | 5 | 222 | 01-Aug-2023, 11:22 AM Last Post: hugnosed_bat | |
Build T-Motor F7 stack - Betaflight Gyro update frequency 3.2kHz ???? | MindBenderFPV | 2 | 3,019 | 18-Jun-2022, 09:10 AM Last Post: SnowLeopardFPV | |
GPS and motor bell fault after a crash | Trial4life42 | 1 | 363 | 12-Apr-2022, 11:43 PM Last Post: kafie1980 | |
Help List of motor size/KV for different props size / LiPo cell count | Oscar | 6 | 1,998 | 24-Mar-2021, 01:39 PM Last Post: Titanv11 | |
Help Brushless motor or ESC broken? Not working properly after full throttle | Niujaus | 5 | 8,161 | 30-Apr-2019, 12:27 PM Last Post: Drone0fPrey |
