SOLVED: see below.
I just got a F4 2G4 board (same board as in the Mobula6). Bare board.
In BF no VTX information comes up at all. Blank screen.
On the photo page they show the solder spot labeled "Onboard vtx SmartAudio"
So which is it? Jumpered (soldered) for onboard vtx, or Non-jumpered (no solder) for onboard vtx?
SOLVED: it was in BF. In the Ports tab the Peripherals column was all blank. I selected vtx-SmartAudio. That turned on the vtx page.
However, the vtx page was all blanks waiting for a json configuration. I pulled the json configuration file from my X12 board and loaded it here. Then finished configuring.
Everything is good.
Everything is good.
