Omnibus F4 V3 No Response
Just unpacked my Eachine Wizard X220S and followed the setup procedures to the letter. The motors were unresponsive to unlock and arming so I tried to connect to Betaflight to see what switches were suppose to be on (I set SWB to Channel 5).
When I connected the quad to the micro-USB the Betaflight app was unresponsive (Serial Port Open then Serial Port closed) and my computer did not recognize it at all..no beep..no nothing. I downloaded Zadig, the STM32 drivers and tried again and still nothing when I plugged into the FC. I took the FC out of the brick stack and held down the bootloader button while I connected the micro-USB and still nothing.
I have watched so many videos and tried many different things but I can not get the FC to recognize as a USB device. I tried on a WIN7 machine and a WIN10 machine and tried several different USB ports and cables. At this point I think I got a DOA FC in my quad.
Am I missing something here?
Have you restarted the PC for the drivers to take effect? That was my problem!  ROFL
(26-Dec-2017, 09:06 PM)Tom BD Bad Wrote: Have you restarted the PC for the drivers to take effect? That was my problem!  ROFL
Several times. I even uninstalled the USB drivers that were there and restarted.
Try the ImpulseRC Driver Fixer
https://impulserc.com/pages/downloads
I believe the wizard uses spf3. You just need the cp210x driver.
hi Eageleye, welcome to IntoFPV.
I had a similar problem with a FC, but eventually realized I was flashing the wrong firmware. Ultimately though I was still able to get it to connect in DFU mode.
Do you happen to have any other quads or FCs around that you can connect to your computer? If you do, do they connect just fine? If they do then it might just be the board, especially if it's not connecting in DFU mode.
carl.vegas
  Help No response flight controller with receiver Crazyart 1 244 09-Jan-2024, 12:53 AM
Last Post: Crazyart
Smile Help Omnibus f4 sd won't arm Omnibusf4sd.5inch 9 524 06-Apr-2023, 08:31 AM
Last Post: Omnibusf4sd.5inch
  Help Omnibus F4 bad 3.3v MojoFlow 5 639 11-Sep-2022, 06:39 AM
Last Post: Lemonyleprosy
  Help Matek F405 No USB response kavil194 6 864 11-Feb-2022, 02:57 PM
Last Post: kafie1980
  MANGO AIO OMNIBUS F3 FC W/ PDB Stardog FPV 8 769 09-Feb-2022, 04:15 PM
Last Post: Stardog FPV
