The smallest and lightest F3 brushed flight controller, NUKE from FuriousFPV.
Dimension is only 16x16mm hole size and weight 1.5g, integrated with 6 Fets (supports hex frame), bec, lc filter, this cannot be smaller.
I really think they could get rid of the mounting holes, for brushed quad we normally just use double sided tapes. But because the components are placed on both sides of the PCB, but that means it might not be levelled when mounting it with double sided tape, as components might not be even horizontally.
This FC is so tiny i think it might even fit in a tiny whoop!
Update - there will be 2 versions, one for standoff mounts, one for double sided tape mount.
Update
connection diagram
Dimension
Update
connection diagram
Dimension
