Nose drop to the left and down
Hey guys,
I have some problems with fine tuning my quad.
The quad sounds good, some mild oscillations when making a sharp turn (propwash) wich can relate to a bit high D in my log?
But my biggest problem wich I can't get rid of is the nose drop when I perform some small throttle punches. The nose will dive and pull to the left a small bit. I want my quad to fly at the same attitude after the small punches. I've watched a lot of videos from Joshau and according to my idea this is a I term problem.
I've tried different I values from 35 till 80 but can't get rid of this problem. I've got this problem with and without my xiaomi yi on the top.
Do you guys have any suggestions? or can help me to fine tune this quad?
setup:
Warpquad 230 (incl armattan micro pod)
Cobra 2204 2300kv
racerstar 30a v2 blheli_s blheli 16.3
Motof3 fc betaflight 3.0
dalprop 5045 triblade
blackbox link: https://www.dropbox.com/s/o5stbhlvm9fbwq...2.TXT?dl=0
# BetaFlight/MOTOLAB 3.0.0 Sep 11 2016 / 00:35:05 (a21694b)
# name
name -
# mixer
mixer QUADX
# servo
# servo mix
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -OSD
feature -BLACKBOX
feature -TRANSPONDER
feature -AIRMODE
feature RX_PPM
feature VBAT
feature FAILSAFE
feature BLACKBOX
# beeper
beeper -GYRO_CALIBRATED
beeper RX_LOST
beeper -RX_LOST_LANDING
beeper -DISARMING
beeper -ARMING
beeper -ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper -GPS_STATUS
beeper -RX_SET
beeper -ACC_CALIBRATION
beeper -ACC_CALIBRATION_FAIL
beeper -READY_BEEP
beeper -MULTI_BEEPS
beeper -DISARM_REPEAT
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
# map
map TAER1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
aux 0 0 0 900 1475
aux 1 25 1 900 1500
aux 2 27 0 900 1475
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# master
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rc_interpolation = AUTO
set rc_interpolation_interval = 19
set rssi_ppm_invert = OFF
set max_aux_channels = 6
set debug_mode = NONE
set min_throttle = 1050
set max_throttle = 2000
set servo_center_pulse = 1500
set max_esc_throttle_jump = 0
set use_unsynced_pwm = OFF
set motor_pwm_protocol = MULTISHOT
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set disarm_kill_switch = ON
set small_angle = 25
set fixedwing_althold_dir = 1
set sbus_inversion = ON
set spektrum_sat_bind = 0
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_default_lattitude =  0.000
set frsky_default_longitude =  0.000
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set battery_capacity = 0
set vbat_scale = 110
set vbat_hysteresis = 1
set current_meter_scale = 400
set current_meter_offset = 0
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = 0
set gyro_lpf = OFF
set gyro_sync_denom = 2
set gyro_lowpass_level = NORMAL
set gyro_lowpass = 90
set gyro_notch_hz = 0
set gyro_notch_cutoff = 130
set moron_threshold = 32
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 2
set yaw_deadband = 2
set yaw_control_direction = 1
set yaw_motor_direction = 1
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set airmode_activate_throttle = 1350
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set gimbal_mode = NORMAL
set acc_hardware = NONE
set acc_lpf_hz =  10.000
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set acc_trim_roll = 0
set pid_process_denom = 1
set blackbox_rate_num = 1
set blackbox_rate_denom = 2
# profile
profile 2
set yaw_p_limit = 500
set dterm_lowpass_level = HIGH
set dterm_lowpass = 100
set dterm_notch_hz = 260
set dterm_notch_cutoff = 160
set pid_at_min_throttle = ON
set iterm_throttle_gain = 0
set pterm_srate_ratio = 85
set dterm_setpoint_weight = 100
set yaw_rate_accel_limit = 220
set rate_accel_limit = 0
set accum_threshold = 130
set yaw_accum_threshold = 32
set yaw_lowpass = 0
set pid_controller = BETAFLIGHT
set p_pitch = 66
set i_pitch = 63
set d_pitch = 43
set p_roll = 66
set i_roll = 63
set d_roll = 43
set p_yaw = 70
set i_yaw = 45
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
# rateprofile
set rc_rate = 102
set rc_rate_yaw = 112
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 80
set pitch_srate = 80
set yaw_srate = 75
set tpa_rate = 15
set tpa_breakpoint = 1550
Thanks a lot already!
Kind regards,
Niels
Could this phenomenon be caused by a rough running motor? it's a bit heavy to remove the shaft. maybe it's a problem with the bearings?
(16-Oct-2016, 11:23 PM)allrounder_w.l.c. Wrote: Could this phenomenon be caused by a rough running motor? it's a bit heavy to remove the shaft. maybe it's a problem with the bearings?
What frame are you flying? And have you ever lubed the bearings? The Cobra motor bearings are very dry from the factory.
Are the props tight on the motor shaft?  If one of them is slipping, it could cause this.  Usually (not always) they will make a loud chirping sound when they slip.  Probably not it, but it's worth a look. Thinking
If the nose drops evenly when punching (not just one motor), then it could be a CG problem. Try moving your battery back a bit.
Could be CG, could be a motor not responding as fast as others (bad solder joint, damaged esc or motor)...
Other than increasing min_throttle or PID to fight the symptom, you could maybe try enabling iterm_throttle_gain which boosts i-term during rapid throttle changes, from what i understand.
  A bunch of left-overs... kaitylynn 16 1,205 12-Jul-2020, 02:11 PM
Last Post: kaitylynn
