Noob struggling with PIDs :)
Hi, I have build my first quadcopter and getting it tuned is a bit over my head. I have watched many youtube videos and blog posts about that. I had 2 crashes when tuning, nothing major. It flies and feels almost good but wobbles a bit when descending and there are some vibrations on videos...  so I would need some help. The ROLL D and PITCH D are strange, are they do high? If I'm looking other PID samples at iNav wiki then my I seams to be to high?
Quad:
Reptile Alien X 500 Frame
2212 920KV motors with 9450 Props
F20A ESCs with simonk
FLIP32+ FC with NEO6M GPS
2 AXIS gimbal at front.
iNav 1.1 software
1.38kg
CLI DUMP:
Entering CLI Mode, type 'exit' to return, or 'help'
# dump
# INAV/NAZE 1.1.0 May 11 2016 / 02:37:17 (1f49891)
# pflags
# Persistent config flags: 0x00000001
# dump master
# mixer
mixer QUADX
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -ONESHOT125
feature -BLACKBOX
feature RX_PPM
feature VBAT
feature GPS
feature FAILSAFE
feature LED_STRIP
feature DISPLAY
feature ONESHOT125
feature BLACKBOX
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
# map
map AETR1234
serial 0 129 115200 38400 0 250000
serial 1 2 115200 57600 0 115200
led 0 0,0::WA:0
led 1 0,0:::0
led 2 0,0:::0
led 3 0,0:::0
led 4 0,0:::0
led 5 0,0:::0
led 6 0,0:::0
led 7 0,0:::0
led 8 0,0:::0
led 9 0,0:::0
led 10 0,0:::0
led 11 0,0:::0
led 12 0,0:::0
led 13 0,0:::0
led 14 0,0:::0
led 15 0,0:::0
led 16 0,0:::0
led 17 0,0:::0
led 18 0,0:::0
led 19 0,0:::0
led 20 0,0:::0
led 21 0,0:::0
led 22 0,0:::0
led 23 0,0:::0
led 24 0,0:::0
led 25 0,0:::0
led 26 0,0:::0
led 27 0,0:::0
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
set looptime = 2000
set emf_avoidance = OFF
set i2c_overclock = OFF
set gyro_sync = OFF
set gyro_sync_denom = 2
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rssi_ppm_invert = OFF
set rc_smoothing = ON
set min_throttle = 1100
set max_throttle = 2000
set servo_center_pulse = 1500
set 3d_deadband_throttle = 1000
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set disarm_kill_switch = ON
set small_angle = 25
set gps_provider = UBLOX
set gps_sbas_mode = EGNOS
set gps_dyn_model = AIR_1G
set gps_auto_config = ON
set gps_auto_baud = ON
set inav_accz_unarmedcal = ON
set inav_use_gps_velned = OFF
set inav_gps_delay = 200
set inav_gps_min_sats = 6
set inav_w_z_baro_p =  0.350
set inav_w_z_gps_p =  0.200
set inav_w_z_gps_v =  0.200
set inav_w_xy_gps_p =  1.000
set inav_w_xy_gps_v =  2.000
set inav_w_z_res_v =  0.500
set inav_w_xy_res_v =  0.500
set inav_w_acc_bias =  0.010
set inav_max_eph_epv =  1000.000
set inav_baro_epv =  100.000
set nav_disarm_on_landing = ON
set nav_use_midthr_for_althold = ON
set nav_extra_arming_safety = ON
set nav_user_control_mode = ATTI
set nav_position_timeout = 5
set nav_wp_radius = 100
set nav_max_speed = 300
set nav_manual_speed = 500
set nav_manual_climb_rate = 200
set nav_landing_speed = 200
set nav_land_slowdown_minalt = 500
set nav_land_slowdown_maxalt = 2000
set nav_emerg_landing_speed = 500
set nav_min_rth_distance = 500
set nav_rth_tail_first = OFF
set nav_rth_alt_mode = AT_LEAST
set nav_rth_altitude = 1000
set nav_mc_bank_angle = 30
set nav_mc_hover_thr = 1675
set nav_mc_min_fly_thr = 1200
set nav_fw_cruise_thr = 1400
set nav_fw_min_thr = 1200
set nav_fw_max_thr = 1700
set nav_fw_bank_angle = 20
set nav_fw_climb_angle = 20
set nav_fw_dive_angle = 15
set nav_fw_pitch2thr = 10
set nav_fw_roll2pitch = 75
set nav_fw_loiter_radius = 5000
set spektrum_sat_bind = 0
set telemetry_switch = OFF
set telemetry_inversion = OFF
set frsky_default_lattitude =  0.000
set frsky_default_longitude =  0.000
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set battery_capacity = 0
set vbat_scale = 110
set vbat_warning_cell_voltage = 34
set current_meter_scale = 400
set current_meter_offset = 0
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = CW180FLIP
set align_board_yaw = 900
set gyro_lpf = 42HZ
set moron_threshold = 32
set imu_dcm_ki = 50
set imu_dcm_kp_mag = 10000
set imu_dcm_ki_mag = 0
set pos_hold_deadband = 20
set alt_hold_deadband = 50
set yaw_control_direction = 1
set yaw_motor_direction = 1
set yaw_jump_prevention_limit = 150
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set failsafe_delay = 10
set failsafe_off_delay = 200
set failsafe_throttle = 1000
set failsafe_procedure = RTH
set rx_min_usec = 950
set acc_hardware = 0
set baro_use_median_filter = ON
set baro_hardware = 0
set mag_hardware = 0
set blackbox_rate_num = 1
set blackbox_rate_denom = 2
set blackbox_device = SERIAL
set magzero_x = -84
set magzero_y = -41
set magzero_z = 76
set acczero_x = 30
set acczero_y = 7
set acczero_z = -8
set accgain_x = 4090
set accgain_y = 4079
set accgain_z = 4072
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# dump profile
# profile
aux 0 0 0 1800 2100
aux 1 2 1 1800 2100
aux 2 3 3 1800 2100
aux 3 9 2 1800 2100
aux 4 10 2 1400 1625
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
set nav_alt_p = 50
set nav_alt_i = 0
set nav_alt_d = 0
set nav_vel_p = 100
set nav_vel_i = 50
set nav_vel_d = 10
set nav_pos_p = 65
set nav_pos_i = 120
set nav_pos_d = 10
set nav_posr_p = 180
set nav_posr_i = 15
set nav_posr_d = 100
set nav_navr_p = 10
set nav_navr_i = 5
set nav_navr_d = 8
set deadband = 5
set yaw_deadband = 5
set throttle_tilt_comp_str = 0
set default_rate_profile = 0
set gimbal_mode = NORMAL
set mag_declination = 800
set p_pitch = 72
set i_pitch = 70
set d_pitch = 75
set p_roll = 72
set i_roll = 70
set d_roll = 75
set p_yaw = 100
set i_yaw = 40
set d_yaw = 0
set p_level = 65
set i_level = 10
set d_level = 75
set max_angle_inclination_rll = 300
set max_angle_inclination_pit = 300
set gyro_soft_lpf_hz = 60
set acc_soft_lpf_hz = 15
set dterm_lpf_hz = 40
set yaw_lpf_hz = 30
set yaw_p_limit = 300
# dump rates
# rateprofile
set rc_rate = 70
set rc_expo = 70
set rc_yaw_expo = 20
set thr_mid = 50
set thr_expo = 0
set roll_rate = 0
set pitch_rate = 0
set yaw_rate = 0
set tpa_rate = 0
set tpa_breakpoint = 1500
 BlackBox Log - https://drive.google.com/file/d/0ByEpVxj...sp=sharing
Thanks,
Jarno
Ok, made some changes:
dterm_lpf_hz = 30
set gyro_soft_lpf_hz = 50
and cut some D
and it's much smoother nowSmile thanks to Dziku.
There are still bounces when doing quick turn on roll axis. Here is latest dump and BB log.
# dump
# pflags
# dump master
# mixer
mixer QUADX
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -ONESHOT125
feature -BLACKBOX
feature RX_PPM
feature VBAT
feature GPS
feature FAILSAFE
feature LED_STRIP
feature DISPLAY
feature ONESHOT125
feature BLACKBOX
# beeper
beeper RX_LOST
beeper DISARMING
beeper ARMING
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper READY_BEEP
beeper MULTI_BEEPS
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
# map
map AETR1234
led 0 0,0::WA:0
led 1 0,0:::0
led 2 0,0:::0
led 3 0,0:::0
led 4 0,0:::0
led 5 0,0:::0
led 6 0,0:::0
led 7 0,0:::0
led 8 0,0:::0
led 9 0,0:::0
led 10 0,0:::0
led 11 0,0:::0
led 12 0,0:::0
led 13 0,0:::0
led 14 0,0:::0
led 15 0,0:::0
led 16 0,0:::0
led 17 0,0:::0
led 18 0,0:::0
led 19 0,0:::0
led 20 0,0:::0
led 21 0,0:::0
led 22 0,0:::0
led 23 0,0:::0
led 24 0,0:::0
led 25 0,0:::0
led 26 0,0:::0
led 27 0,0:::0
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
set looptime = 2000
set gyro_sync = OFF
set rssi_scale = 30
set gyro_lpf = 42HZ
set imu_dcm_ki = 50
set magzero_x = -84
set magzero_y = -41
set magzero_z = 76
set acczero_x = 30
set acczero_y = 7
set acczero_z = -8
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# dump profile
# profile
aux 0 0 0 1800 2100
aux 1 2 1 1800 2100
aux 2 3 3 1800 2100
aux 3 9 2 1800 2100
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
set nav_alt_p = 50
set nav_alt_i = 0
set nav_alt_d = 0
set nav_vel_p = 100
set nav_vel_i = 50
set nav_vel_d = 10
set nav_pos_p = 65
set nav_pos_i = 120
set nav_pos_d = 10
set nav_posr_i = 15
set nav_navr_p = 10
set nav_navr_i = 5
set nav_navr_d = 8
set deadband = 5
set p_pitch = 72
set i_pitch = 70
set d_pitch = 50
set p_roll = 72
set i_roll = 70
set d_roll = 50
set p_yaw = 100
set i_yaw = 40
set d_yaw = 0
set p_level = 65
set i_level = 10
set d_level = 75
set dterm_lpf_hz = 30
set yaw_lpf_hz = 30
# dump rates
# rateprofile
set rc_rate = 70
set rc_expo = 70
set thr_mid = 50
set thr_expo = 0
set roll_rate = 0
set pitch_rate = 0
set yaw_rate = 0
set tpa_rate = 0
Blackbox log - https://drive.google.com/file/d/0ByEpVxj...sp=sharing
  Please help! Need to relate PIDs with quad behaviour... silverAG 10 3,453 25-Oct-2017, 09:19 AM
Last Post: unseen
  Super High PIDS! rryyyaann 5 1,897 19-May-2017, 01:14 AM
Last Post: rryyyaann
  Wobble and PIDS? paulsmith 5 3,842 22-Jul-2016, 01:34 AM
Last Post: JimmyLe813
  BlackBox PIDs tuning, support welcome... pasaff68 3 1,695 23-Mar-2016, 03:17 PM
Last Post: pasaff68
