No stick movements on SuperX FC ELRS
I got this SuperX FC and connected to ERLS 3 radio but can't get stick moved
This is built-in ELRS as  UART 2 where I set  BF 'Serial Rx" . Both rx and tx (radio) is ELRS 3.3 now
[Image: 1JtnNT9l.jpg]
[Image: 4OXCSDkl.png]
Can you post photos of wiring and a dump file.
  • niuk
Updated first post with picture, UART based ELRS is built-in
[Image: 1vtqCN0l.png]
# diff
# Betaflight / STM32F411 (S411) 4.4.2 Jun  1 2023 / 04:11:35 (23d066d08) MSP API: 1.45
# config: YES
# start the command batch
batch start
board_name CRAZYBEEF4DX
manufacturer_id HAMO
# name: SuperX3
serial 0 131073 115200 57600 0 115200
# beeper
beeper -ARMED
aux 0 0 0 1300 2100 0 0
aux 1 1 1 1150 1550 0 0
aux 2 13 2 1700 2100 0 0
aux 3 35 1 1550 2100 0 0
# vtxtable
vtxtable bands 5
vtxtable channels 8
vtxtable band 1 BOSCAM_A A CUSTOM     0    0    0    0    0    0    0    0
vtxtable band 2 BOSCAM_B B CUSTOM     0    0    0    0    0    0    0    0
vtxtable band 3 BOSCAM_E E CUSTOM     0    0    0    0    0    0    0    0
vtxtable band 4 FATSHARK F CUSTOM     0 5760    0 5800    0    0    0    0
vtxtable band 5 RACEBAND R CUSTOM  5658 5695 5732 5769 5806 5843 5880 5917
vtxtable powerlevels 3
vtxtable powervalues 14 23 0
vtxtable powerlabels 25 200 0
# master
set gyro_lpf1_static_hz = 0
set gyro_lpf2_type = PT2
set gyro_lpf2_static_hz = 375
set dyn_notch_count = 1
set dyn_notch_q = 500
set gyro_lpf1_dyn_min_hz = 187
set gyro_lpf1_dyn_max_hz = 375
set acc_calibration = 79,-17,6,1
set dshot_idle_value = 600
set dshot_bidir = ON
set motor_poles = 12
set motor_output_reordering = 2,0,3,1,4,5,6,7
set vbat_max_cell_voltage = 440
set vbat_min_cell_voltage = 300
set vbat_warning_cell_voltage = 320
set yaw_motors_reversed = ON
set small_angle = 180
set simplified_gyro_filter_multiplier = 75
set osd_tim1 = 770
set osd_vbat_pos = 2433
set osd_rssi_pos = 33
set osd_link_quality_pos = 2071
set osd_rssi_dbm_pos = 3079
set osd_tim_1_pos = 3244
set osd_tim_2_pos = 3308
set osd_flymode_pos = 2583
set osd_g_force_pos = 65
set osd_throttle_pos = 33
set osd_vtx_channel_pos = 2049
set osd_current_pos = 384
set osd_mah_drawn_pos = 384
set osd_craft_name_pos = 2589
set osd_pilot_name_pos = 2578
set osd_warnings_pos = 329
set osd_avg_cell_voltage_pos = 2465
set osd_disarmed_pos = 2549
set osd_displayport_device = MSP
set osd_canvas_width = 50
set osd_canvas_height = 18
set vtx_band = 5
set vtx_channel = 8
set vtx_power = 1
set vtx_freq = 5917
set vcd_video_system = HD
set gyro_1_sensor_align = CW0
set craft_name = SuperX3
set pilot_name = Irek
profile 2
# profile 2
set dterm_lpf1_dyn_min_hz = 101
set dterm_lpf1_dyn_max_hz = 202
set dterm_lpf1_static_hz = 101
set dterm_lpf2_static_hz = 202
set iterm_relax_cutoff = 20
set p_pitch = 66
set i_pitch = 77
set d_pitch = 61
set f_pitch = 160
set p_roll = 67
set i_roll = 78
set d_roll = 60
set f_roll = 162
set p_yaw = 67
set i_yaw = 78
set f_yaw = 162
set d_min_roll = 60
set d_min_pitch = 61
set d_max_advance = 0
set thrust_linear = 20
set feedforward_jitter_factor = 5
set feedforward_boost = 18
set feedforward_max_rate_limit = 95
set simplified_pids_mode = OFF
set simplified_master_multiplier = 120
set simplified_i_gain = 65
set simplified_d_gain = 200
set simplified_pi_gain = 150
set simplified_dmax_gain = 0
set simplified_feedforward_gain = 135
set simplified_pitch_d_gain = 90
set simplified_pitch_pi_gain = 95
set simplified_dterm_filter_multiplier = 135
set tpa_rate = 80
set tpa_breakpoint = 1250
# rateprofile 0
set roll_rc_rate = 20
set pitch_rc_rate = 20
set yaw_rc_rate = 20
set roll_expo = 50
set pitch_expo = 50
set yaw_expo = 25
set roll_srate = 50
set pitch_srate = 50
set yaw_srate = 50
# end the command batch
batch end
Can you post a full dump and not just the diff.
  • niuk
What TX do you have? Does the ELRS lua show they are connected? Can you put both TX and RX into WiFi mode and show screenshots of the webui?
https://www.expresslrs.org/quick-start/w...the-web-ui
[-] The following 1 user Likes V-22's post:
  • niuk
I have RM Zorro, ELRS 3 doing fine with couple of quads. I was able to get wifi on SuperX FC , screenshots coming...
[Image: 26BtfUkl.png]..
Is the VTX antenna shorted against the board? That enameled copper wire should be extended out straight and not touching anything.
Can you show the receiver tab in Betaflight? What does the ELRS lua on the radio show when the quad is powered on?
  • niuk
Radio says "receiver still connected" when I try to power off, then "telemetry lost" when FC powered off. Screenshot and picture coming..
[Image: VZx2kZll.png]
[Image: erHKJcGl.jpg]
In the ELRS lua on your radio, set telemetry ratio to Std, and set VTX Admin -> Band to Off.
Can you also show a screenshot of the Model tab in the receiver's webui?
Do you have any other ELRS TX or RX?
I would also try reflashing both via USB/Passthrough, with "Erase flash" checked in ELRS Configurator:
https://www.expresslrs.org/quick-start/t...assthrough
https://www.expresslrs.org/quick-start/r...assthrough
Just a weird guess. Is your input assigned on your radio?
(10-Nov-2023, 11:30 PM)voodoo614 Wrote: Just a weird guess. Is your input assigned on your radio?
I am using many quads on same ELRS TX and profile
Tried different Radio, same thing connected but no stick movement. Also standard telemetry and Band OFF on radio didn't help. I upgraded firmware on whoop thru wifi and same thing
[Image: 0nlDhN3l.png]
Don't see anything obviously wrong. Might be DOA FC.
(11-Nov-2023, 03:22 PM)niuk Wrote: Tried different Radio, same thing connected but no stick movement. Also standard telemetry and Band OFF on radio didn't help. I upgraded firmware on whoop thru wifi and same thing
Uncheck model match and click save.
#15
nothing to do with the issue, butbi would suggest to mount the antenna as straight as possible and as faraway to the board as possible. while elrs is magic amd does work astonishing well on that monopole antenna, that mounting does make that magic more difficult :-)
  • niuk
  Pavo Pico elrs bricked! Please help!! Jackstinn 10 258 21-Apr-2024, 04:06 PM
Last Post: mstc
  Express LRS connects but no stick movement AMMistry18 28 736 15-Apr-2024, 06:28 AM
Last Post: AMMistry18
  Issues Installing ELRS Reciever NyxOTNC 14 1,627 04-Apr-2024, 08:07 PM
Last Post: tr8d3r8
  VTX+ELRS Placement JohnnyCornRocket 4 174 19-Mar-2024, 02:36 PM
Question Elrs receiver blinks green once? FeuerKai 5 207 09-Mar-2024, 10:05 PM
Last Post: FeuerKai
