12-Feb-2023, 11:44 AM (This post was last modified: 12-Feb-2023, 02:41 PM by GreyCookie.)
EDIT: It now worked, build everything together and now its not working anymore..
Where could be the problem when RSSI works and nothing else?
Hey Guys
Normally I'm a passive reader but now I also have to present a problem which holds me up for months now.
What do I use:
Before the jumper T-Pro I had a Taranis X Lite S with XM+ Receiver. I couldn't get it to work and thought its the issue with FrSky they created, the whole mess with ACCESS and ACCST.
Got an Archer M+ from FrSky and tried everything with that one - same problem - no stick input on the receiver tab. Transmitter kept loosing connection. FlightController showed some sparks, bought the same one again.
Sold the Taranis X Lite S and the transmitters because I was fed up with 'em...
Got the Jumper T Pro and ELRS Receiver - desoldered the Jumper on the FC which was on SBUS mode and soldered it to DSM mode.
Flashed the internal module on Transmitter to 3.1.2 CE_LBT and the Receiver to 3.1.2 over WIFI
Tried to invert SerialRX and turned the inversion off again.
Im working on this since October with waiting times in-between for the new parts
https://www.flickr.com/photos/[email protected]/
For Layout check, this is the FC:
https://betafpv.com/collections/brushles...heli_32-v4
This is the RX:
https://betafpv.com/collections/rx/produ...e-receiver
I tried to implement everything that people have asked for in previous postings to make this as easy as possible, I'll be happy to update any further information, so anyone else having same issues can benefit from this thread.
(I tried really hard to integrate the photos but no chance, Imgur neither took PNG, HEIC, JPEG nor JPG. When attaching, nothing happens even if I reduce the images to 497kB and when embedding the image, there is only a white question mark on a blue background.... I didn't think it was so difficult to get photos onto this big big internet. )
Hey Guys
What do I use:
- Jumper T-Pro ELRS (EdgeTX 2.7.0) delivered straight with the proper arm switch mounted instead of the momentary ones - Internal Module flashed to 3.1.2 CE_LBT over wifi
- ELRS Lite Receiver
- Toothpick F405 2-4S AIO Brushless Flight Controller 20A (BLHELI_32)
- Betaflight Configurator 10.8.0
- DJI FPV Googles Version 1 with analog input
- baseplate for drone was a eachine novice 1
- Passphrase binding worked. Can access WIFI of Receiver.
- I get RSSI back, Transmitter tells me connection established when turning on the quad and connection lost when turning of - works good.
- I can turn motors in Betaflight and got them all to turn the correct way
- haven't tried video yet
No stick input in Receiver Tab although Receiver binds to Transmitter.
This is the RX:
