no control stick operation (cleanflight)
Hello All,
I have a flip32+ ,  works with baseflight, (except can not arm using sticks)
flashed to clean flight and I get no stick operation (receiver shows no signal).
I am using PWM and PPM was not selected , even tried the types of receivers, still no response.
Any ideas ?
Hey,
can you show us a screenshot of your setup-page and maybe a CLI dump?
It's hard to tell this way.
I could only guess at wrong connector (port), or port not enabled, or PWM not set properly, or no ground between RX and FC (one ground cable only please).
Sky is where the fun begins!
Flying: Armattan F1-6 / Cobra 1960kv / KISS / 1800mAh nano's / SPR3 / Betaflight 2kHz
Building: FPV49v4 modified
  Help TX Sticks Control - Thumber vs. Pincher MacFly90 12 21,095 19-Oct-2023, 03:08 AM
Last Post: psfales
  Discussion Inav simultaneous wifi and RC control glassTransition 1 247 18-Oct-2023, 12:48 PM
Last Post: fpvapnea
  Help Out of control rayb106 6 478 20-Jan-2022, 11:36 AM
Last Post: rayb106
  RX Loss flag and control without transmitter mwon 1 736 25-Oct-2021, 12:57 PM
Last Post: kafie1980
  ImpulseRC Apex Lipo Pad Doesn't Stick the.ronin 10 1,212 23-Jan-2020, 12:15 AM
Last Post: kingstar
