30-Dec-2017, 08:48 PM
once the quad racer is bound... how and what are the next steps to arm the quad..
NExt Steps ????? |
30-Dec-2017, 08:48 PM once the quad racer is bound... how and what are the next steps to arm the quad.. 30-Dec-2017, 09:36 PM 30-Dec-2017, 09:53 PM (This post was last modified: 30-Dec-2017, 09:54 PM by raspberrypi33.) In Betaflight, go to "modes" (on the left hand of the Betaflight configurator).Then, from the drop down menu saying "aux_" under the "arm" setting(the _ corresponds to the channel on the transmitter), drag and resize the colored slider so that after you press save in the lower right hand corner, the "arm" tile is lit in yellow. Make sure to take your props off while doing this b/c you could chop off a finger or worse if you aren't careful or if something goes wrong. I made this mistake once when something went weird on the quad, and it gave me a cut on the finger, ripped a handful of keys off my keyboard, and caused general chaos around my work area! Also, check out Joshua Bardwell's Youtube channel b/c he has a lot of Betaflight tutorials! Happy flying! If it ain't broke, DON'T FIX IT! My YouTube FPV Channel |
My first UAV experience and next steps | UglyBob | 5 | 144 | 20-Mar-2024, 03:17 AM Last Post: UglyBob | |
Solved IMAX B6 jumps in 100mAh steps | whoelseisbored | 6 | 412 | 04-Dec-2020, 01:05 PM Last Post: SnowLeopardFPV |
