Threads: 1
Likes Received: 1 in 1 posts
1 Hi Everyone,
I’ve been into rc for many years and only recently got the hang of quad flying.
I bought an inductrix pro and now im hooked on the quad bug.
I flew the inductrix till I burnt out the fc when one of the motors shorted out. I replaced the fc with a betafpv f3 with osd and the motors with 19500kv. The old motors were 1900kv.
The quad flies lots better with the new setup
Happy flying
Threads: 83
Likes Received: 944 in 654 posts
Likes Given: 2,142
24 Welcome to the best forum for FPV aussieMailman! I started at a similar place to you, with an Eachine H8 mini and E010. Moved up to a
KingKong Tiny7 which is like an over-sized (75mm) inductrix.
A great quad to progress to is the
Bat-100 which uses 0705 brushless motors, but still uses 1s batteries, probably one of the quickest 1s models you can find. I was so impressed with it, that I designed
2 slightly larger chassis' so it can be fitted with slightly longer (65 & 66mm) props, than the stock 56mm, to try and maximize the thrust. I have not received or tested these frames yet though...
Anyway, I hope you enjoy your time on the forum as much as I do!
Threads: 129
Likes Received: 2,740 in 1,644 posts
Likes Given: 2,969
65 Welcome to IntoFPV, the best FPV forum to be found
SoCal Kaity :D
OMG, no one told me it would be this much fun! Addicted :)
Threads: 89
Likes Received: 1,283 in 768 posts
Likes Given: 1,274
31 Catching up with my welcomes
hi welcome to the site! I hope you come back sometime!
carl.vegas
Current Quads: Operational: Diatone GT2 200 In need of repair: Bumble Bee, tehStein, Slightly modified Vortex 250
