Threads: 29
Likes Received: 5 in 5 posts
Likes Given: 94
0 I noticed an update with the TBS agent X so I installed it. After that my crossfire micro tx had an update so I installed that. Now my micro tx had to update the receivers in all my quads. I went to fly and now my radio is saying rx signal critical ? The menus have changed in my radio and I’m not sure what settings I should be on ? I asked Joshua Bardwell but he said he’s on the current update and nothing has changed. Anyone update this and have issues ? Sorry if this is in the wrong place to ask.
Threads: 587
Likes Received: 8,966 in 6,634 posts
Likes Given: 1,425
788 TBS Agent X 3.0.42 (the current latest version) has been out for a while now so it won't be related to that.
I've been running firmware version 4.11 on my Crossfire receivers since it got released back at the beginning of the year and I've had no issues with it. I've read of some issues with firmware versions 6.07 and 6.09 so I have stayed away from those for now. If you are facing problems then I suggest you roll back to firmware version 4.11 and see if that resolves your signal issue.
Threads: 16
Likes Received: 176 in 149 posts
Likes Given: 26
8 28-Sep-2021, 06:40 PM (This post was last modified: 28-Sep-2021, 06:40 PM by MrSolo.) Make sure your RX's are still on the right frequency. (update might have re-set them?)
I have had some come on Euro's 868mhz freq. which causes terrible range here in the US because that freq. is used for other things here so we use 915mhz.
Go into the RX's menu on your transmitter and I think it is under 'General' you can make sure it is on the right freq. for you.
