Threads: 47
Likes Received: 114 in 84 posts
Likes Given: 76
1 Looks like the soldering work is decent and everything is going to the correct place. Have you tried the camera on another rig?
Threads: 2
Likes Received: 1 in 1 posts
0 Yes. Popped the camera onto another rig and it works perfectly. Seems to be in the FC or vTX. The video goes through the FC. I don’t know if I’m missing something in the setup of one of them or if one is defective. Was hoping it was just a misconfiguration and not a failure. All parts are brand new.
Threads: 47
Likes Given: 76
1 Hmm... I'm not even sure what the button does exactly, but did you check the "vtx" checkbox under the configuration tab? If you can validate the camera, then it's probably good unless it's not being fed enough juice. I would try and do the same with the vtx if possible. Put it on another build to test.
Threads: 125
Likes Given: 99
388 Everything appears to be wired correctly. Are you able to scan for frequency on your VRX? If yes, try it. The frequency might be off from the one you actually picked.
Threads: 672
Likes Given: 2,030
139 try connecting the camera signal wire and the VTX signal wire, see if that works?
that would allow you to rule out whether it's the FC or the VTX that isn't working.
Threads: 2
0 This is embarrassing. The problem is the new vtx is set to not transmit by default. Doh!
Works now.
Threads: 83
Likes Received: 944 in 654 posts
Likes Given: 2,142
24 Yup, humans... Always expecting the worst..!
Glad you got it sorted man, any other problems, just ask...
