15-Jun-2022, 11:39 PM
DJI announced their new digital transmission system today which is capable of 1080p/60fps and which has been built with the new Ronin RS3 in mind, and while people on here won't really care for this particular product, it does prove what capabilities DJI could give us if they were to continue investing in the FPV market. Those antennas look very familiar I guess we will just have to wait and see if they do end up producing and releasing a much smaller version in Air Unit / Air Unit Lite size based on this same technology that is aimed at the UAV market. They would clearly need to get the latency down for that though because 68ms or 100ms is just too much for FPV.
DJI Product Page: https://www.dji.com/transmission
Specifications
Specifications
- Weight
- Video Transmitter Weight: Approx. 350 g / 0.77 lbs (excluding antennas)
- High-Bright Remote Monitor Weight: Approx. 727 g / 1.6 lbs (excluding antennas)
- Dimensions
- Video Transmitter: 127×87×26 mm (L×W×H, excluding antennas)
- High-Bright Remote Monitor: 213×135×51 mm (L×W×H, excluding antennas)
- Operating Frequency
- "Non DFS Frequency Band:
2.4000-2.4835 GHz
5.150-5.250 GHz
5.725-5.850 GHz
- DFS Frequency Band:
5.250-5.350 GHz
5.470-5.600 GHz
5.650-5.725 GHz"
- Transmitter Power (EIRP)
- 2.4000-2.4835 GHz:
<33 dBm (FCC)
<20 dBm (SRRC/CE/MIC)
- 5.150-5.250 GHz:
<23 dBm (FCC/SRRC/MIC)
- 5.250-5.350 GHz:
<30 dBm (FCC)
<23 dBm (SRRC/MIC)
- 5.470-5.600 GHz, 5.650-5.725 GHz:
<30 dBm (FCC)
<23 dBm (CE/MIC)
- 5.725-5.850 GHz:
<33 dBm (FCC/SRRC)
<14 dBm (CE)
- Max Bandwidth: 40 MHz
- Max Bitrate: 50 Mbps
- Power Consumption: 11 W
- Power Supply Voltage: 6 to 18 V
- Output Voltage: Power Output Port 6 to 18 V
- Operating Time
- Video Transmitter: 3 hours 40 minutes [1]
- High-Bright Remote Monitor: 2 hours [1]
- Input Video Format
- 3G SDI: YCbCr 4:2:2 10-bit
- HDMI RGB 4:4:4
- 1080p: 23.98/24/25/29.97/30/50/59.94/60fps
- 1080i: 50/59.94/60fps
- 720p: 50/59.94/60fps
- Output Video Format
- Input Audio Format: SDI embedded, HDMI embedded
- Output Audio Format: PCM
- Video Transmission System: O3 Pro
- Max Video Bitrate: 50 Mbps
- Video Transmission Latency: 68 ms [1], 100 ms [1]
- Video Coding Format: H.264
- Max Transmission Distance: 6 km (FCC) [2], 4 km (CE/SRRC/MIC) [2]
- Operating Temperature: -10° to 45° C (14° to 113° F)
- Mirror Control Mode Supported Camera Models: ZV1/A7 III/A7S III/A7M III/A7R III/A7R IV/A7 IV/FX3/A7S II/A6600/A6400 and all Sony cameras that support BRAVIA (HDMI control).
- Measured with the equipment in a level and stationary state, the gimbal balanced, three axes in an active state, and the battery only powering the gimbal.
- In open environments free of obstructions or interference.
