Need some help with Matek 5 in 1 PDB setup
So I have a new build going and am using the Matek 5 in 1 PDB.   I can power up with a 3s battery and the ESCs all power up just fine.   However, when I connect the wires from the PDB (signal, hot, and ground), to the Naze32 (ESC #5) the PDB beeps constantly.
Here is how I understand I can set this up:    I have a 3 way toggle switch on my Taranis set to Channel 5 coming into my D4R2 rx.   I have verified that it is working.   The Matek instructions say to plug the PDB into the Aux1 channel.   So now I need to set ESC #5 to Aux 1 so I can toggle the PDB.
The config part I should be able to figure out, but I can't figure out why I get the constant beeping.
(17-Mar-2016, 12:28 AM)Tony Schroeder Wrote: So I have a new build going and am using the Matek 5 in 1 PDB.   I can power up with a 3s battery and the ESCs all power up just fine.   However, when I connect the wires from the PDB (signal, hot, and ground), to the Naze32 (ESC #5) the PDB beeps constantly.
Just a thought here..Is the Low voltage alarm set too high at present for the current state of your test lipo?
(17-Mar-2016, 01:56 AM)BigglesFPV Wrote: Just a thought here..Is the Low voltage alarm set too high at present for the current state of your test lipo?
Yes, I checked that.   I am getting 12.48 volts from my lipo.   The low voltage alarm is set to 3.6
Have you gone ahead and configured ESC #5 as AUX1? Then if it's beeping couldn't you just reverse the channel in your Tx?
(22-Mar-2016, 09:48 AM)Relic Wrote: Have you gone ahead and configured ESC #5 as AUX1? Then if it's beeping couldn't you just reverse the channel in your Tx?
I actually enabled gimbal/pan and then connected to the ESC #1 as described in this post:  http://intofpv.com/t-setting-up-matek-5i...red-device
But if you could show me how to configure ESC #5 to Aux 1 that would be great.
(17-Mar-2016, 02:49 AM)ts_hunter Wrote: Yes, I checked that.   I am getting 12.48 volts from my lipo.   The low voltage alarm is set to 3.6
According to the manual, you can set the voltage for this.
  Powering Pixhawk using Matek FCHUB-12S PDB EZDRONE 1 415 11-Jul-2021, 07:02 PM
Last Post: voodoo614
  PDB utility? reelu 5 441 07-Feb-2021, 10:38 AM
Last Post: reelu
  Pdb current sensor OneEyedFPV 7 598 09-Oct-2020, 02:24 AM
Last Post: OneEyedFPV
  Matek F722-SE video problem SJChannel 17 6,950 03-Sep-2020, 08:35 PM
Last Post: EVILsteve
  Problems with Matek buzzer SJChannel 25 10,600 07-May-2020, 03:29 AM
Last Post: Mutchy
