17-Mar-2016, 12:28 AM
So I have a new build going and am using the Matek 5 in 1 PDB. I can power up with a 3s battery and the ESCs all power up just fine. However, when I connect the wires from the PDB (signal, hot, and ground), to the Naze32 (ESC #5) the PDB beeps constantly.
Here is how I understand I can set this up: I have a 3 way toggle switch on my Taranis set to Channel 5 coming into my D4R2 rx. I have verified that it is working. The Matek instructions say to plug the PDB into the Aux1 channel. So now I need to set ESC #5 to Aux 1 so I can toggle the PDB.
The config part I should be able to figure out, but I can't figure out why I get the constant beeping.
