Need some help with flashing new Omnibus FW
Hey guys, I have run into an odd problem I can't figure out.
I killed the RX on my Bat 100 FS-A8S, one of the comments following my FS buyers guide on Oscars blog said that the crazy behaviour that I experience at full throttle can be eliminated by wrapping the RX in tin foil. I had de-cased the RX so I wrapped it in insulation/electrical tape beforehand but bricked despite this!
I have now changed the RX for a micro PPM and changed the RX settings in BF, and the receiver tab shows everything working fine. However I am getting the runaway throttle problem, I have flashed the ESC's with the latest FW, but the problem persists.
I wanted to have a look at the 'throttle min check' but don't know where to find it in BF?
Now trying to flash the FC (teeny 1s FC) with newest Omnibus FW (Released  11/01/18), but BF automatically changes the COM port when I try to write the new FW to the board. I can configure the board through COM 11, but when I try to flash it changes to COM 8 and goes through the "opening serial port..." 10 seconds "...serial port closed" and COM 11 has been removed from the drop-down box until I dis and re-connect Huh
I have tried using the stand alone BF configurator app, and the chrome app, but I am getting the same result regardless of full chip erase, manual Baud rate, etc. I haven't tried jumping the boot pins yet...
Flashing should not change the COM. It should change to DFU. I had Zadig go south on me out of nowhere. See if you can flash a different FC that uses DFU. If it doesn't work, then the driver probably needs reinstalling.
  • Tom BD Bad
Yeah, needed to reinstall drivers. Zadig didn't work on my old PC, so I didn't use it on my new laptop, but installing it, installed DFU. Sorted Thanks man!
Also figured out (from the underscore!) that throttle min_check is a cli command, OH RIGHT! Doh
Min_throttle is under the ESC/motor features in configuration tab.
Min_check (low stick) is under the receiver tab.
You don't need to go to CLI for these anymore.
Edit: if you are running Dshot then min_throttle doesn't apply. You has to use idle_up.
  • Tom BD Bad
  Voltage in OSD flashing 0.0V Mpvisuals 11 5,747 23-Mar-2024, 06:51 AM
Last Post: nikhilfpv
  How to connect Rush Tank Ultimate 2 to Omnibus F4 AIO icoryx 1 230 08-Oct-2023, 04:36 PM
Last Post: Rob3ddd
  Omnibus F4 can't get IBUS RX working after flashing tekknyne 4 613 27-Jul-2023, 02:11 PM
Last Post: aster1sc
  Problem flashing Tmotor F7hd Bubbakfpv 5 541 18-Jul-2023, 10:57 PM
Last Post: Lemonyleprosy
  Flashing Betaflight with trainer mode dehein2 0 176 06-Jun-2023, 06:03 PM
Last Post: dehein2
