11-Sep-2021, 08:14 AM
Need help swwaping pin on Matek f405 |
11-Sep-2021, 08:57 AM What do you mean by "change the pin"? What is it exactly that you're trying to do? 11-Sep-2021, 10:12 AM im connecting my flight cntroller to an ESC but the pin for motor 4 has been damaged so I want to use either s5 or s6 iNav does not allow resource mapping like Betaflight does. You will need to compile your own target to change pin assignments in the custom target you compile. Unless you can do something with some custom Mixer but this will be complicated. |
Recently flashed INAV to speedybee f405 and already had issues on quad crash. | grozaalex | 0 | 336 | 03-May-2024, 09:25 PM Last Post: grozaalex | |
[SOLVED] Speedybee F405 Wing servos problem | totor | 1 | 2,867 | 26-May-2023, 02:47 PM Last Post: totor | |
magnetometer on Matek M8Q-5883 | koklimabc | 4 | 1,262 | 08-Mar-2023, 07:54 AM Last Post: koklimabc | |
GPS not working on Matek F405-WMN | Aer0baticCat | 4 | 1,087 | 10-Oct-2022, 02:09 AM Last Post: matt0725 | |
12v LED PWM Switch INAV - Matek F722-WPX | Simpo20 | 5 | 1,596 | 19-Jan-2022, 11:02 AM Last Post: Simpo20 |
