Need help plz
Ok guys! I need your expertise. I'm almost done my first build. Zmr180. I have soldered everything but I can't figure out how to connect the pdb to the FC. I have some pics. I hope you can figure out what I have done. All solder is good checked by volt meter I can't figure out how to post pics. Says the pic is to big
use imgur plugin to post bigger pictures - it will make them smaller. It's in the column to the left of the post editor
Dude. I must be totally mental. I can't find imgur
also what pdb and what fc you have?
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
I have a naze32 rev5 Matek mini hub w/bec5v & 12v. That's what's on the bag. I'm real sorry that I don't know how to post pics.
so you have something like this:
http://d1b5yzykmxw6e8.cloudfront.net/cat...b-lead.jpg
take +5v and ground from (top right corner of the picture i've linked) it and connect to naze on bottom of the picture where you have + and - signs
http://www.radioc.co.uk/v/vspfiles/photos/3009-2.jpg
All the best
So this is just regular wire I use?
(03-Dec-2016, 09:15 PM)Gorgeousguy Wrote: Dude. I must be totally mental. I can't find imgur
Click on "Upload Image", and it opens the Imgur dialog (as shown below)
[Image: Q7mBnNFl.png]
[Image: 2bBpOVLl.png]
Then click "Select File" and browse to find your image.
[Image: GzWbc5Ul.jpg][Image: 1tUpdC7l.jpg][Image: wXnzaNdl.jpg][Image: rstVNzEl.jpg]
the problem for the pics was that i was on my phone. sorry. I will get better(newbie)
yup take 2 wires one red (for +) one black (for -)
presolder the pdb pads to have tin on them.
then presolder the cables, either both sides if you are going to do direct solder to pins/pads or you will be going for the pin connections then on one end you will have pin conector (female) and on other presoldered cable.
(ensure no power is in the system (bettery/usb))
solder wire to pdb, connect or solder the wire to naze... and you should be good (ensure no shorts, using multimeter)
All the best
Thank you so much! Everything has power. Motors turn with use of clean flight. Just can't figure out why there is no power from the 2x5 pins? For the rx. All solder seems fine
Which 2x5 pins do you mean? Did you have check the power with a voltage meter?
The pins that connect to the rx. No I didn't test with a voltage meter. I will do that when I'm back from work. I do know I have power to the board from the 5v
yes you should see the power on this connector (2x5 - naze for pwm/ppm/sbus/lets/gps etc)
on that you should have gnd, +5v, chan 1 (ppm) as output... question is are you using the ppm / pwm or sbus/ibus?
if for any reason the +5v pad or ground is damaged, steal the power from any other +5 and ground areas and you should be good.
on your second pic you should have "nothing pin" - ground, "." pin - +5v, "1" pin - signal for ppm, if you are using ibus/sbus you should use pin 4 if i remember correctly.
All the best
Exclamation motors do not spin from reciever. PLZ HELP I NEED TO GET THIS TO WORK THIS WEEK lottacurry 15 244 21-Mar-2024, 10:46 PM
  My quad won't arm - plz help Egg_FPV 23 1,311 30-Jul-2021, 01:31 PM
  Multiple Problems with Quad! Need expert advice plz Romine4006 8 517 10-Jun-2021, 06:52 PM
Last Post: Romine4006
  I may have went full tard. Help plz. sphyon 10 660 27-Feb-2021, 08:37 PM
Last Post: Fael78BR
  Beginner VTX need help(visual representation plz) Gabe Miller 3 382 19-Aug-2020, 09:49 PM
Last Post: voodoo614
