Naze32 v6 flashing orange light
Proud of myself for finishing my first build a ZMR250. However, have now got the rx to bind with tx, ( I am in PPM) powered up, but have a flashing orange status indicator, with a solid blue light, on the FC. I initially flashed the FC prior to the build to make sure that it was working. I have no problem connecting to Cleanflight. My tx does not arm the quad, I am assuming due to whatever status the FC is in. Could use some of your experience to solve this problem. It's probably a simple fix,he says hopefully. Thanks.
One solid one flashing led normally means the quad is on a angled surface and doesn't allow arming..
1. can you try calibrate ACC on a level surface?
2. can you confirm the bars in receiver tab respond to your sticks?
(24-Jan-2017, 08:56 AM)Oscar Wrote: One solid one flashing led normally means the quad is on a angled surface and doesn't allow arming..
Thank you for your reply Oscar. I found out that I needed to click the rf-ppm in Cleanflight, that cleared the orange flashing light. I appreciate the timely reply. Smile It's nice to know that help is just a post away.
  After flashing the ESC using JESC zomer 1 175 18-Sep-2023, 09:50 AM
Last Post: voodoo614
  Flashing custom BF hex file mstc 0 151 11-Jun-2023, 02:54 PM
Last Post: mstc
  Betafpv spi elrs 12a aio bricked after flashing firmware Dronewhooper 14 1,224 04-Feb-2023, 01:03 AM
Question LED rope light on a switch Zheroz00 2 276 10-Dec-2022, 03:55 AM
Last Post: Zheroz00
  Can flashing the wrong fc firmware damage components Rob Axel 1 958 25-Sep-2022, 10:16 AM
