09-Feb-2016, 08:14 PM
I can only get EMAX 12a speed controls/motors to spin up if I do the following steps in this order...
I disconnect center pin(5v) on speed controls plug them into FC,
Power speed controls up with lipo (not FC),
Plug USB into computer(CleanFlight configurator software not required),
Unplug USB from computer, then I hear speed controls boot up beeps,
Then plug USB back into computer, start up CleanFlight configurator (with OneShot125 off),
Go to motors tab, raise sliders and motors spin up.
IF I then unplug LiPo from speed controls/motors, then plug them back in, motors will no longer work, until I repeat the above process again.
This renders these EMAX 12A speed controls unusable for this NAZE32 Rev6 flight controller.
I will try checking/reprogramming the firmware on the Emax speed controls tonight and see if that fixes it.
(having trouble getting BlHeli to connect to my speed controls now, so maybe later)
These same EMAX 12a speed controls/motors work fine with my CC3D FC.
This same NAZE32 Rev6(no diode) FC, works fine with AFRO esc 12a speed controls and Oneshot125 enabled in Configurator.
Getting everything to work together can be very challenging and involve a lot of time, research, and trial and error experimentation.
