Naze32 rev6 beep codes on power
Lately when my naze32 rev6 is powers on the buzzer gives off 3 fast beeps and 2 slow beeps. Here is my video.
Has anyone seen this before?
While it is beeping like this I can't connect to it via betaflight.
Does it with either battery or USB power
I have the accelerometer off
I have two quads the use the same board.  Mine acts the same way when it powers up but with but the beeps are probably three times as long with longer intervals in-between.  On mine, the three consecutive beeps are the gyros calibrating.  Not sure what is going on with yours...error code maybe? Thinking
Sounds like an error code most probably associated with a dead gyro/gyro not found. I had the same on my rev5 I got from multirotorparts and they confirmed it's a hardware issue and sent me a new one. I was able to flash sometimes, but not connect to gui.
You can try a solder reflow on gyro chip if you want to save this board, I've read it sometimes solves the issue. I just trashed mine.
or you can reuse it as part of an intro to darude sandstorm Smile
question - was it flying before or it is a fresh build? if fresh have you connected the board before soldering stuff on it?
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
It is not a fresh build. The beeping eventually stops and it reboots and everything is fine. I feel like the gyro may be going bad. Just going to bite the bullet and buy a Motolabs Cyclone.
in that case i would order new board and replace it... as this will eventually fail in the crucial moment (electronics is known to break in the worst possible moment)
as you describe it looks lie gyro is starting starting starting... eventually kicks in... question when will it stop ?
All the best
(27-Oct-2016, 10:23 AM)Grisha0 Wrote: in that case i would order new board and replace it... as this will eventually fail in the crucial moment (electronics is known to break in the worst possible moment)
It stops after about 8-10 seconds.  When it does, you hear the FC startup.
  Build What motors for 4" power quad? romangpro 30 2,358 21-Sep-2023, 02:26 AM
Last Post: romangpro
  SpeedyBee F7 V3 Power Issues SoFarKingFast 8 737 13-Jun-2023, 09:54 PM
Last Post: Pennywise
  Help 3" video noise only when armed and only if Unify Pro32 Nano power 400mW+ udy 6 2,074 09-May-2022, 03:26 AM
Last Post: Rob3ddd
  Help Issue with power? ropilofski 14 2,433 03-Oct-2018, 06:33 PM
Last Post: ropilofski
  Help zmr250 Build - Cannot Arm naze32 relentlessly 7 3,043 13-Jul-2016, 02:10 PM
Last Post: JimmyLe813
