Name of quadcopter frames
I know H frame from X frame, but what are the names of frames like the Tweaker and the Hellbender? In one I see flat out front arms and splayed backs, and more frog like front arms in others. I've heard "dead cat", but not sure which of these that would be.
[Image: tweaker-fpva-lead.jpg]
[Image: 12599386_690967867707739_1834239250_n.jp...MA%3D%3D.2]
I think they can be refered to as "Deadcat".
Deadcat and Reverse Deadcat are where either the front or rear arms are X-config and the other arms are H-config. Some know it as asymmetric spider-X. Reverse has the X arms at the front, like the UBAD Inversion, Tweaker. Normal deadcat is H-arms front config, like TBS Disco Pro. Google should explain most of these for you.
BUT! Some might argue that it's to do with the motor position rather than the shape/position of the arms. I call my frame as a deadcat but I have seen people say it's not, it's actually an H frame (wider than it is long). A true deadcat has all four arms the same length, but the front ones are rotated back further than the back ones, this means it's actually much wider in the front than it is at the back.
So it really depends on how you look at it.
[-] The following 3 users Like SkinnyShark's post:
  • BigglesFPV, Oscar, SonicCopter
I refer to all my quads as Roger, or "you stupid piece of Sh*t".
My youtube channel
[-] The following 2 users Like BigglesFPV's post:
  • K24cl9, KonradS
  3.5” frames and Walksnail VTX B4tn 5 680 22-May-2023, 11:57 AM
  New Product BetaFPV X-Knight 35 FPV Quadcopter Bajora 12 1,204 02-Jan-2023, 09:32 PM
Last Post: iFly4rotors
  Discussion Prop pitch vs. quadcopter weight SJChannel 18 6,176 08-Apr-2022, 10:31 PM
Last Post: romangpro
  Looking for a 4” freestyle,what are some good frames? Rob3ddd 16 2,565 09-Jun-2021, 03:33 AM
Last Post: Rob3ddd
  Build Pirat frames Hook build! "The Cursed One" Flickeryvision 9 2,641 27-Sep-2020, 07:15 PM
Last Post: Flickeryvision
