My quads are going nuts
I have built 5 quads using the CC3D controller. They oscillate a lot in flight and one even flips over on take off. I have used Open Flight and Libre Flight with the same results. I have not changed the PID settings from the default. Any ideas what I might try?
It would make it easier if you emailed me directly at [email protected]. I am trying to reduce vibration to the board but it still is not right.
This is the best PID tuning video I have seen. Easy to follow. I use the cc3d and it definitely needs tuning from the defaults. Hope this helps.
For the one that flips over on take-off: check board- or sensor-orientation, motor order. If those are correct, try to increase min_throttle (or digital idle if using dshot).
In case you are using sensor-orientation, be aware that "default" does not mean zero degrees on the cc3d.
  No OSD, Converted analog to HDZero Quads FPVme 14 249 24-Mar-2024, 08:35 PM
  Boxer SA Switch will NOT Arm my Quads soky157 35 1,055 01-Mar-2024, 12:29 PM
  Prop Nuts f33dback 1 195 26-Oct-2023, 09:27 PM
Last Post: f33dback
  Arm / fly two quads w/one controller on crossfire? Rob Axel 2 216 15-Jan-2023, 07:45 PM
  Slight bump makes quad go nuts! Lol Egg_FPV 2 282 17-Dec-2022, 05:25 PM
Last Post: BadRaven
