16-Feb-2018, 03:07 AM
Hi all!
I've since few weeks finish my first setup. When I fly it, it's really nice, really smooth, but as soon as I want make some freestyle (flip etc...) it is soooo Slow!
If i push the roll, it will flip very very veeeery slowly! If i take some altitude, and try it higher, I will push it longer to make the "slow flip" but instead to make one, it will make two! and then crash....
When I do it at 30cm and try to flip, I even have not enough time to reverse the quad than it's already crash as it is sooo slow.
I've tried lot of different PID, I tried to make it very fast but nothing help....
Even my kingkong Tiny 7 is faster...
The setup is:
Frame AWESOME F200
Camera runcam swift 2
Motor emax RS2205 2300KV
prop Dalprop T5045C
FC Matek F405 OSD
ESC 4in1 BS30 (or something like that, 30A hollywing if i remember).
VTX Foxeer 200mW + LC filter (I had noise when i push the throttle)
RX frsky XM+
The DIFF:
# diff
# Betaflight / MATEKF405 (MKF4) 3.2.3 Dec 11 2017 / 07:51:34 (cb962eda1) MSP API: 1.36
# name
name Leurne
# resources
# mixer
# servo
# servo mix
feature MOTOR_STOP
feature DYNAMIC_FILTER
# beeper
beeper -ON_USB
# map
# color
# mode_color
aux 0 0 0 1800 2100
aux 1 1 1 1800 2100
aux 2 2 1 1300 1700
aux 3 13 2 1725 2100
aux 4 36 3 900 1175
# adjrange
# rxrange
# vtx
# rxfail
# master
set gyro_lowpass_hz = 50
set acc_trim_pitch = 2
set acc_trim_roll = -54
set min_throttle = 1040
set disarm_kill_switch = OFF
set osd_cap_alarm = 950
set osd_vbat_pos = 2072
set osd_rssi_pos = 40
set osd_tim_1_pos = 54
set osd_tim_2_pos = 33
set osd_flymode_pos = 2537
set osd_throttle_pos = 225
set osd_vtx_channel_pos = 377
set osd_current_pos = 385
set osd_mah_drawn_pos = 2048
set osd_craft_name_pos = 2528
set osd_gps_speed_pos = 218
set osd_gps_lon_pos = 82
set osd_gps_lat_pos = 65
set osd_gps_sats_pos = 51
set osd_home_dir_pos = 302
set osd_home_dist_pos = 303
set osd_compass_bar_pos = 266
set osd_altitude_pos = 247
set osd_pid_roll_pos = 423
set osd_pid_pitch_pos = 455
set osd_pid_yaw_pos = 487
set osd_debug_pos = 1
set osd_power_pos = 321
set osd_pidrate_profile_pos = 345
set osd_warnings_pos = 2546
set osd_avg_cell_voltage_pos = 76
set osd_pit_ang_pos = 257
set osd_rol_ang_pos = 289
set osd_battery_usage_pos = 392
set osd_disarmed_pos = 2123
set osd_nheading_pos = 311
set osd_nvario_pos = 279
set osd_esc_tmp_pos = 82
set osd_esc_rpm_pos = 83
set osd_stat_min_rssi = OFF
set osd_stat_bbox = OFF
set osd_stat_bb_no = OFF
set osd_stat_tim_1 = ON
# profile
set dterm_lowpass_type = PT1
set anti_gravity_gain = 2000
set setpoint_relax_ratio = 33
set dterm_setpoint_weight = 106
set p_roll = 45
set i_roll = 48
set p_yaw = 90
set i_level = 100
set d_level = 100
# rateprofile
set rc_rate = 82
set rc_rate_yaw = 82
set rc_expo = 11
set rc_expo_yaw = 9
set roll_srate = 87
set pitch_srate = 87
set yaw_srate = 87
The setup is:
Frame AWESOME F200
prop Dalprop T5045C
FC Matek F405 OSD
RX frsky XM+
The DIFF:
# diff
# name
name Leurne
# resources
# mixer
# servo
# servo mix
feature MOTOR_STOP
# beeper
beeper -ON_USB
# map
# color
# mode_color
aux 0 0 0 1800 2100
aux 1 1 1 1800 2100
aux 2 2 1 1300 1700
aux 4 36 3 900 1175
# adjrange
# rxrange
# vtx
# rxfail
# master
# profile
set p_roll = 45
set i_roll = 48
set p_yaw = 90
set i_level = 100
set d_level = 100
# rateprofile
set rc_rate = 82
set rc_expo = 11
set rc_expo_yaw = 9
set roll_srate = 87
set yaw_srate = 87
