My quad is rolling chaotic in BlackBox Log
Hello all,
This is my first build and I need some help to identify what happend in my blackbox log. My quad is rolling like crazy. This does not reflect the real situation because the quad is flying ok. Flight Mode was :Angle
My setup is:
GPS: UBLOX M8N (mag_align = CW90deg flip- heading values ok when pointing N,S,E,V)
Frame : Jumper 266 (250 class)
FC: Omnibus F3 AIO (orientation 180 deg YAW)
Firmware:INAV
Motors:Emax MT2204
ESC's:Emax nano 20A (flashed with Biheli standard 14.1)
Props:KingKong 5x4.5x3
gyro alignment: default
accel alignment: default
BB Log (1/1)
Thanks in advance!
# dump
# INAV/OMNIBUS 1.7.2 Jul 20 2017 / 11:40:53 (81b85de)
# resources
# servo
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
# servo mix
smix reset
feature -VBAT
feature -CURRENT_METER
feature -DASHBOARD
feature -BLACKBOX
feature -TRANSPONDER
feature -AIRMODE
feature -SUPEREXPO
feature -VTX
feature -RX_SPI
feature -SOFTSPI
feature -PWM_SERVO_DRIVER
feature -PWM_OUTPUT_ENABLE
feature -OSD
feature VBAT
feature RX_SERIAL
feature GPS
feature TELEMETRY
feature CURRENT_METER
feature BLACKBOX
feature PWM_OUTPUT_ENABLE
# beeper
beeper RUNTIME_CALIBRATION
beeper HW_FAILURE
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACTION_SUCCESS
beeper ACTION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper LAUNCH_MODE
map AETR1234
# name
name -
serial 20 1 115200 38400 0 115200
serial 0 32 115200 38400 0 115200
serial 1 2 115200 115200 0 115200
serial 2 64 115200 38400 0 115200
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
aux 0 0 0 900 1200
aux 1 1 1 900 1250
aux 2 2 1 1350 1650
aux 3 20 1 1750 2100
aux 4 3 4 1300 1700
aux 5 9 4 1300 1700
aux 6 8 5 1800 2100
aux 7 11 2 1700 2100
aux 8 17 0 900 1300
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# master
set looptime = 1000
set gyro_sync = ON
set gyro_sync_denom = 4
set align_gyro = DEFAULT
set gyro_hardware_lpf = 256HZ
set gyro_lpf_hz = 90
set moron_threshold = 32
set gyro_notch1_hz = 400
set gyro_notch1_cutoff = 300
set gyro_notch2_hz = 200
set gyro_notch2_cutoff = 100
set vbat_adc_channel = 1
set rssi_adc_channel = 3
set current_adc_channel = 2
set airspeed_adc_channel = 0
set acc_notch_hz = 0
set acc_notch_cutoff = 1
set align_acc = DEFAULT
set acc_hardware = MPU6000
set acc_lpf_hz = 15
set acczero_x = 141
set acczero_y = -10
set acczero_z = -497
set accgain_x = 4059
set accgain_y = 4089
set accgain_z = 4017
set align_mag = CW90FLIP
set mag_hardware = HMC5883
set mag_declination = 0
set magzero_x = 59
set magzero_y = -29
set magzero_z = -145
set mag_calibration_time = 30
set baro_hardware = BMP280
set baro_use_median_filter = ON
set min_check = 1100
set max_check = 1900
set rssi_channel = 16
set rssi_scale = 30
set rssi_invert = OFF
set rc_smoothing = ON
set serialrx_provider = SBUS
set sbus_inversion = ON
set spektrum_sat_bind = 0
set blackbox_rate_num = 1
set blackbox_rate_denom = 2
set blackbox_device = SDCARD
set sdcard_detect_inverted = ON
set min_throttle = 1064
set max_throttle = 2000
set motor_pwm_rate = 1000
set motor_pwm_protocol = ONESHOT125
set failsafe_delay = 5
set failsafe_recovery_delay = 5
set failsafe_off_delay = 200
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set failsafe_stick_threshold = 50
set failsafe_fw_roll_angle = -200
set failsafe_fw_pitch_angle = 100
set failsafe_fw_yaw_rate = -45
set align_board_yaw = 1800
set gimbal_mode = NORMAL
set battery_capacity = 0
set vbat_scale = 110
set current_meter_scale = 400
set current_meter_offset = 0
set current_meter_type = ADC
set yaw_motor_direction = 1
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lpf_hz = 20
set flaperon_throw_offset = 200
set tri_unarmed_servo = ON
set imu_dcm_ki = 50
set imu_dcm_kp_mag = 10000
set imu_dcm_ki_mag = 0
set small_angle = 25
set fixed_wing_auto_arm = OFF
set disarm_kill_switch = ON
set gps_provider = UBLOX
set gps_sbas_mode = EGNOS
set gps_dyn_model = AIR_1G
set gps_auto_config = ON
set gps_auto_baud = ON
set gps_min_sats = 6
set deadband = 5
set yaw_deadband = 5
set pos_hold_deadband = 20
set alt_hold_deadband = 50
set fw_autotune_overshoot_time = 100
set fw_autotune_undershoot_time = 200
set fw_autotune_threshold = 50
set fw_autotune_ff_to_p_gain = 10
set fw_autotune_ff_to_i_tc = 600
set inav_auto_mag_decl = ON
set inav_gravity_cal_tolerance = 5
set inav_use_gps_velned = ON
set inav_gps_delay = 200
set inav_reset_altitude = FIRST_ARM
set inav_max_surface_altitude = 200
set inav_w_z_surface_p =  3.500
set inav_w_z_surface_v =  6.100
set inav_w_z_baro_p =  0.350
set inav_w_z_gps_p =  0.200
set inav_w_z_gps_v =  0.500
set inav_w_xy_gps_p =  1.000
set inav_w_xy_gps_v =  2.000
set inav_w_z_res_v =  0.500
set inav_w_xy_res_v =  0.500
set inav_w_acc_bias =  0.010
set inav_max_eph_epv =  1000.000
set inav_baro_epv =  100.000
set nav_disarm_on_landing = OFF
set nav_use_midthr_for_althold = OFF
set nav_extra_arming_safety = ON
set nav_user_control_mode = ATTI
set nav_position_timeout = 5
set nav_wp_radius = 100
set nav_wp_safe_distance = 10000
set nav_auto_speed = 300
set nav_auto_climb_rate = 500
set nav_manual_speed = 500
set nav_manual_climb_rate = 200
set nav_landing_speed = 200
set nav_land_slowdown_minalt = 500
set nav_land_slowdown_maxalt = 2000
set nav_emerg_landing_speed = 500
set nav_min_rth_distance = 500
set nav_rth_climb_first = ON
set nav_rth_climb_ignore_emerg = OFF
set nav_rth_tail_first = OFF
set nav_rth_allow_landing = ON
set nav_rth_alt_mode = AT_LEAST
set nav_rth_abort_threshold = 50000
set nav_rth_altitude = 1000
set nav_mc_bank_angle = 30
set nav_mc_hover_thr = 1500
set nav_mc_auto_disarm_delay = 2000
set nav_fw_cruise_thr = 1400
set nav_fw_min_thr = 1200
set nav_fw_max_thr = 1700
set nav_fw_bank_angle = 20
set nav_fw_climb_angle = 20
set nav_fw_dive_angle = 15
set nav_fw_pitch2thr = 10
set nav_fw_loiter_radius = 5000
set nav_fw_land_dive_angle = 2
set nav_fw_launch_velocity = 300
set nav_fw_launch_accel = 1863
set nav_fw_launch_max_angle = 45
set nav_fw_launch_detect_time = 40
set nav_fw_launch_thr = 1700
set nav_fw_launch_idle_thr = 1000
set nav_fw_launch_motor_delay = 500
set nav_fw_launch_spinup_time = 100
set nav_fw_launch_timeout = 5000
set nav_fw_launch_climb_angle = 18
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_default_latitude =  0.000
set frsky_default_longitude =  0.000
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set smartport_uart_unidir = OFF
set ibus_telemetry_type = 0
set ltm_update_rate = NORMAL
set osd_video_system = 0
set osd_row_shiftdown = 0
set osd_units = METRIC
set osd_rssi_alarm = 20
set osd_cap_alarm = 2200
set osd_time_alarm = 10
set osd_alt_alarm = 100
set osd_main_voltage_pos = 2060
set osd_rssi_pos = 2071
set osd_flytimer_pos = 2423
set osd_ontime_pos = 2391
set osd_flymode_pos = 2444
set osd_throttle_pos = 2273
set osd_vtx_channel_pos = 200
set osd_crosshairs = 0
set osd_artificial_horizon = 2248
set osd_current_draw_pos = 2265
set osd_mah_drawn_pos = 2233
set osd_craft_name_pos = 84
set osd_gps_speed_pos = 2113
set osd_gps_sats_pos = 2400
set osd_gps_lon = 2432
set osd_gps_lat = 2464
set osd_home_dir = 2159
set osd_home_dist = 2081
set osd_altitude_pos = 2049
set osd_vario = 182
set osd_vario_num = 247
set osd_pid_roll_pos = 322
set osd_pid_pitch_pos = 354
set osd_pid_yaw_pos = 386
set osd_power_pos = 47
set i2c_overclock = OFF
set debug_mode = NONE
set acc_task_frequency = 500
set attitude_task_frequency = 100
set async_mode = ALL
set throttle_tilt_comp_str = 0
set mode_range_logic_operator = OR
set stats = OFF
set stats_total_time = 0
set stats_total_dist = 0
# profile
profile 1
set mc_p_pitch = 58
set mc_i_pitch = 50
set mc_d_pitch = 22
set mc_p_roll = 43
set mc_i_roll = 40
set mc_d_roll = 20
set mc_p_yaw = 70
set mc_i_yaw = 45
set mc_d_yaw = 0
set mc_p_level = 20
set mc_i_level = 15
set mc_d_level = 75
set fw_p_pitch = 5
set fw_i_pitch = 7
set fw_ff_pitch = 50
set fw_p_roll = 5
set fw_i_roll = 7
set fw_ff_roll = 50
set fw_p_yaw = 6
set fw_i_yaw = 10
set fw_ff_yaw = 60
set fw_p_level = 20
set fw_i_level = 5
set fw_d_level = 75
set max_angle_inclination_rll = 300
set max_angle_inclination_pit = 300
set dterm_lpf_hz = 80
set yaw_lpf_hz = 30
set dterm_setpoint_weight =  0.000
set fw_iterm_throw_limit = 165
set fw_reference_airspeed =  1000.000
set fw_turn_assist_yaw_gain =  1.000
set dterm_notch_hz = 260
set dterm_notch_cutoff = 160
set pidsum_limit = 500
set yaw_p_limit = 300
set iterm_ignore_threshold = 200
set yaw_iterm_ignore_threshold = 50
set rate_accel_limit_roll_pitch = 0
set rate_accel_limit_yaw = 10000
set heading_hold_rate_limit = 90
set nav_mc_pos_z_p = 50
set nav_mc_pos_z_i = 0
set nav_mc_pos_z_d = 0
set nav_mc_vel_z_p = 100
set nav_mc_vel_z_i = 50
set nav_mc_vel_z_d = 10
set nav_mc_pos_xy_p = 65
set nav_mc_pos_xy_i = 120
set nav_mc_pos_xy_d = 10
set nav_mc_vel_xy_p = 180
set nav_mc_vel_xy_i = 15
set nav_mc_vel_xy_d = 100
set nav_fw_pos_z_p = 50
set nav_fw_pos_z_i = 0
set nav_fw_pos_z_d = 0
set nav_fw_pos_xy_p = 75
set nav_fw_pos_xy_i = 5
set nav_fw_pos_xy_d = 8
set rc_expo = 70
set rc_yaw_expo = 20
set thr_mid = 50
set thr_expo = 0
set roll_rate = 80
set pitch_rate = 80
set yaw_rate = 65
set tpa_rate = 0
set tpa_breakpoint = 1500
Hm i wouldn't interpret too much into this... The blackbox viewer got a bunch of updates recently and angle mode has low to no priority for most devs. Could be this is just a bug.
(20-Aug-2017, 12:47 PM)fftunes Wrote: Hm i wouldn't interpret too much into this... The blackbox viewer got a bunch of updates recently and angle mode has low to no priority for most devs. Could be this is just a bug.
yes, I upgraded  to new desktop BlackBox reader and problem it was solved.
Thanks
[-] The following 1 user Likes AlinP's post:
  • fftunes
  Where to put 2.4GHz ELRS RX with ceramic antenna on 5in racing quad? Luk5569 6 167 05-Mar-2024, 12:54 PM
Last Post: ph2t
  Data Zombie Quad? Green_Weedle 2 138 05-Feb-2024, 10:27 PM
  How quad building has helped my Beer brewing Rob Axel 5 224 16-Oct-2023, 01:24 AM
  Help Find my quad aerokam 16 805 10-Oct-2023, 04:52 PM
Last Post: Dak_4008
  Help Help needed - blackbox file samples to finetune Flight time prediction model whiterabbit 1 227 25-Jul-2023, 12:20 AM
Last Post: whiterabbit
