My Latest Build aka: The Beast
[Image: n7WKeuel.jpg]
[Image: J6GtuPGl.jpg]
[Image: gY7Whghl.jpg]
[Image: b0WuEevl.jpg]
Pyro Drone HyperLite 4mm Frame
RaceFlight Revolt flight controller modified for optimal soft mounting.
DYS XS30A ESCs running multishot
Matek HUBOSD8-SE PDB
RunCam Swift
HyperLite V3 Team Edition 2206-2450kv Motors also soft mounted
Lumenier Butter Cutter Props
LaForge VTX
and....... the best part........ 5S batteries.  Thumbs Up
[-] The following 3 users Like JimmyLe813's post:
  • sloscotty, fftunes, Drone0fPrey
Beast looks like a beauty! Wink
Nice build Jimmy Cool
The Obsession IS Real!
Nice!
I have been curious about soft-mounted motors. It has seemed to me like you could easily introduce some unwanted vertical alignment problems (must be doable or not so many would be doing it). Do you set the screws to a specific torque or use some other "trick" to keep that from happening? Or does it just not matter?
(05-Feb-2017, 11:13 AM)sloscotty Wrote: Nice!
what i did was use 6mm screws for the motors. i always used two screws to mount motors. so i figured a 4mm frame, 1mm thick soft mount, which leaves about 1mm for the motor. i used thread lock (loctite), and thightened the screws till i can about a thread or two coming through the bottom of the inside of the motors. you will be able to feel the soft mounts compress a little bit causing a little torque on the screws.
[-] The following 1 user Likes JimmyLe813's post:
  • sloscotty
  Build Rekon5 UL 5" build ph2t 51 7,992 12-Apr-2024, 02:26 AM
Last Post: ph2t
  Build Micro Apex 4" Build drumgod 8 396 11-Apr-2024, 12:05 AM
Last Post: BigBeard
  Build Helios - 3.5” Sub-250g (Sub 160g possible) DJI O3 Drone – Frame/Build Thread Recursion 12 1,862 25-Mar-2024, 10:28 PM
Last Post: Recursion
  Build 5in lightweight build hawk01 37 1,360 22-Mar-2024, 10:56 AM
Last Post: Jossey
  Build Whoosh - 3.5" build. PID settings? maxer 23 1,166 30-Dec-2023, 08:29 PM
