Posts: 29 Threads: 4 Likes Received: 30 in 11 posts Likes Given: 26 Joined: Jul 2017 Reputation: 5 21-Jul-2017, 12:24 AM (This post was last modified: 22-Jul-2017, 03:58 PM by FPVdroneshotz.) So now that we are flying FPV, I'm spending most of my time fixing the quad and getting pretty good at at. On that note, I decided with our down time, while waiting for parts all the time, we would start building our first quad. I'm getting good at soldering and Tyler is actually learning to solder too. So here's what we've selected thus far. We are learning so I wanted to put this out to the group and see what you guys think. I've been learning so much from all of you, so please make any recommendations or observations. Drone Build: SpaceOne 220X - thanks SloScotty PDB XT60 - 11g Betaflight F3 FC - 8.6g Foxeer HS1177 - 14.6g Emax 2205s 2300K with Bullet 30a’s - 115g + 15.6g = 130.6g Frsky Taranis X8R VTX - Maybe the TBS - not sure here Antenna - Not sure either, but leaning towards the Immersion RC All Silicone Wiring TechFlex for Wire covering Tatu Batteries 4s - 155g GoPro Session • Posts: 2,416 Threads: 51 Likes Received: 1,861 in 1,175 posts Likes Given: 3,315 Joined: Mar 2016 Reputation: 74 I would go with a shorter or "stubby" antenna. For the same price, the AXii are very good: http://www.getfpv.com/lumenier-axii-5-8g...-rhcp.html. For a lot less money the Aomway Shorts are good: http://www.getfpv.com/aomway-short-5-8gh...-rhcp.html That's the first time I've seen that frame, so I don't know, but I might go with something more "popular". I have a SpaceOne 220X that I like more and more all the time (4.5mm main plate, 2mm top plate). He's got them for 29.99 currently. But others might have better recommendations. • Posts: 12,099 Threads: 125 Likes Received: 3,738 in 2,835 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 I wouldn't go with the X8R. Made that mistake on my first build. It is too big and expensive. You will likely be using SBUS and S.Port. I would go with no pin X4Rsb, XSR or XSR-M. Posts: 29 Threads: 4 Likes Received: 30 in 11 posts Likes Given: 26 Joined: Jul 2017 Reputation: 5 (21-Jul-2017, 01:54 AM)sloscotty Wrote: I would go with a shorter or "stubby" antenna. For the same price, the AXii are very good: http://www.getfpv.com/lumenier-axii-5-8g...-rhcp.html. For a lot less money the Aomway Shorts are good: http://www.getfpv.com/aomway-short-5-8gh...-rhcp.html That's the first time I've seen that frame, so I don't know, but I might go with something more "popular". I have a SpaceOne 220X that I like more and more all the time (4.5mm main plate, 2mm top plate). He's got them for 29.99 currently. But others might have better recommendations. O.k. sloscotty, I went with the SpaceOne X220. Seems like a rock. Which is what I need! I just need a PDB. Which PDB did you find? I'm staying with the Betaflight F3 FC. Thanks, Mark Posts: 2,416 Threads: 51 Likes Received: 1,861 in 1,175 posts Likes Given: 3,315 Joined: Mar 2016 Reputation: 74 (22-Jul-2017, 03:59 PM)FPVdroneshotz Wrote: O.k. sloscotty, I went with the SpaceOne X220. Seems like a rock. Which is what I need! I just need a PDB. Which PDB did you find? I'm staying with the Betaflight F3 FC. I think you'll like that frame. You won't need a PDB with that FC. The Betaflight F3 is an all-in-one - it has a built-in PDB. Posts: 29 Threads: 4 Likes Received: 30 in 11 posts Likes Given: 26 Joined: Jul 2017 Reputation: 5 (22-Jul-2017, 04:24 PM)sloscotty Wrote: I think you'll like that frame. You won't need a PDB with that FC. The Betaflight F3 is an all-in-one - it has a built-in PDB. totally missed that... • Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 As voodoo stated earlier, I would definitely change out the X8R for something smaller. Looking forward to seeing your first build come together! • Posts: 72 Threads: 2 Likes Received: 32 in 22 posts Likes Given: 1 Joined: Jun 2017 Reputation: 0 Maybe look into pagoda antennas. Cheap as beans and perform great, just make sure to get some which has some sort of protection. • Posts: 29 Threads: 4 Likes Received: 30 in 11 posts Likes Given: 26 Joined: Jul 2017 Reputation: 5 O.k... thanks for all the tips guys! Mostly all the parts are in and I started the build. As I laid out the motors and the esc's for soldering, I put a screw in each motor to hold them snug while soldering. My question is ---- even only one screw, loosely tightened, seems to make the motor very tough to move. I then tried putting in all 4 screws to see what that does and it barely moves just using my fingers to turn it. I used m3 screws (the short ones) that came with the motors. Seems strange that they are so tight. Any thoughts? Also, I'm contemplating motor guards on the SpaceOne 220x. Did any of you get motor guards for those? I'm using the emax 2205's (red bottoms). • Posts: 1,590 Threads: 89 Likes Received: 1,283 in 768 posts Likes Given: 1,274 Joined: Jan 2017 Reputation: 31 but the motors spin fine without the screws in? that is odd... considering the construction of a motor the bell housing shouldn't be impeded by the screws. The big issue with screw length is in touching the stator. carl.vegas Current Quads: Operational: Diatone GT2 200 In need of repair: Bumble Bee, tehStein, Slightly modified Vortex 250 • Posts: 29 Threads: 4 Likes Received: 30 in 11 posts Likes Given: 26 Joined: Jul 2017 Reputation: 5 Yup. Moves nice and easy when not screwed in, but very tight when mounted. Crazy? It's the Emax 2205's. • Posts: 2,416 Threads: 51 Likes Received: 1,861 in 1,175 posts Likes Given: 3,315 Joined: Mar 2016 Reputation: 74 Is the hole in the center of the motor mount large enough to clear the clip, etc, on the bottom of the motor? Posts: 29 Threads: 4 Likes Received: 30 in 11 posts Likes Given: 26 Joined: Jul 2017 Reputation: 5 That's it Scotty! The clip and shaft is sitting on the arm. Maybe using the soft mounts will help. I got the ones for the 2205's, so that should give me enough space. If it's not one thing..... what a learning curve! Posts: 2,416 Threads: 51 Likes Received: 1,861 in 1,175 posts Likes Given: 3,315 Joined: Mar 2016 Reputation: 74 03-Aug-2017, 10:03 AM (This post was last modified: 03-Aug-2017, 10:15 AM by sloscotty.) (03-Aug-2017, 02:55 AM)FPVdroneshotz Wrote: That's it Scotty! The clip and shaft is sitting on the arm. Maybe using the soft mounts will help. I got the ones for the 2205's, so that should give me enough space. If it's not one thing..... what a learning curve! Well, it's not your fault. The frame maker changed the design since I bought my frame. In the photos below, the one on the top is the original design (the one I have), and the one on the bottom is the new design. I'm not sure why he did that - very poor choice on his part, if you ask me. With that bolt on the bottom of the Emax, I'm not sure a even a soft mount will provide enough clearance. You might have to drill out that center hole (not safe or easy without a drill press and clamps - and safety glasses and face mask). Hopefully the bolt head will fit in that hole and the soft mount will help clear the shoulder (washer?) on the bolt. Let us know (and complain to Spaceone!). Posts: 1,590 Threads: 89 Likes Received: 1,283 in 768 posts Likes Given: 1,274 Joined: Jan 2017 Reputation: 31 03-Aug-2017, 10:17 AM (This post was last modified: 03-Aug-2017, 10:19 AM by Carl.Vegas.) (03-Aug-2017, 10:03 AM)sloscotty Wrote: ...You might have to drill out that center hole (not safe or easy without a drill press and clamps - and safety glasses and face mask). ... I had to learn the difficulty of increasing the size of a hole on a carbon fiber frame the hard way when making a hole bigger for an FPV antenna... definitely not easy or safe! (I had never tried drilling carbon fiber before). Luckily I didn't get hurt but still it was a pretty frustrating exercise, even just on a 2mm top plate... I can't imagine what it would be like with a 4mm arm. carl.vegas Current Quads: Operational: Diatone GT2 200 In need of repair: Bumble Bee, tehStein, Slightly modified Vortex 250 |
