Multishot help
After selecting Multishot in Betaflight, i can no longer arm the quad, FC LED just flashes slowly.
I am using Naze32 R5, cicada Blheli_s 20A esc (multishot supported)
Do I need to enable multishot in BLHeliSuite? I thought protocol is detected automatically?
I think you need at least 2K looptime to run multishot:
http://intofpv.com/t-enable-multishot-in-betaflight
and make sure your CPU load isn't too high (should be below 30% when idlee on the desk)
Try to disable ACC and other unneeded features.
If still no luck, try to move back to oneshot?
Thanks!
Turns out the naze rev5 is overloading on 2k/2k so i had to lower it
  Multishot on Racerstar ESCs? bombarie 3 2,970 28-Sep-2016, 08:13 PM
Last Post: bombarie
  Aikon SEFM 30A and multishot mockyrc70 0 1,014 12-Sep-2016, 02:16 PM
Last Post: mockyrc70
  Help Flash Multishot to SN20A BL20A ESC? OverDischarged 1 2,691 02-Jul-2016, 01:51 AM
Last Post: SkinnyShark
