09-Apr-2017, 07:00 PM
I was reading an article by Oscar Liang this morning about setting up a Taranis so that you can control your PIDs and VTx with a KISS FC. (link https://oscarliang.com/change-pid-vtx-se...ment-14166) However it seems that from everything I can find you can only use one serial port on the KISS FC, so you have to choose one serial device (Bluetooth, OSD, SmartPort audio, BlackBox etc), even though it seems there are 3 Rx/Tx pads on the board itself. I would love to get this setup so I could control my PIDs and Vtx via my Taranis, but not if it means giving up my OSD.
Has anyone found a way to connect multiple serial devices to a KISS FC? It seems like with all the options out there now that require serial connections there has to be a way to get this done, but im not hopeful as the KISS GUI only lists a single configuration option which appears to be for Rx/Tx1.
