Mounting Motors?
Having done all the test assembly I need to do with my frame (refer to the Cheap250 build thread) I'm coming to the point where I have to commit things to Loctite and get ready for flight.
So when it comes to mounting motors:
  • Loctite - Yes or No?
  • Is there any trick vibration damping one can do when mounting?
  • Lock-Washers?
Whats have you tried and had success (or spectacular failure) with?
A Blog
The use of loctite is a good idea, no need to use washers unless your screws are too long, and would not worry about any anti vibration dampening at all.
My youtube channel
Loctite - yes. Unless you are using FC with a vibration-vulnerable gyro (ie. naze32 rev6), then just put M3 orings between a spacer and a nut above and below the FC. You *can* mount your motors the same way, but that's shouldn't be necessary. I think your KK board doesn't need too much vibration dampening - you already mounted it on foamy tape right?
Lochte (blue) would be ok . I always just use 2 screws to mount each motor . Shouldnt have to dampen anything where motors mount.
as you can see everyone will agree with using loctite on your motor mounting screws, but I would also suggest using it on the screws to hold your frame together also. losing a screw on your frame can cause vibration on your quad. a little trick I use is I'll use a cap from a water bottle or something and put a few drops of loctite in it and I'll just dip the tip of each screw before screwing it in this way I don't accidentally put to much so that the whole screw is dripping in it.
Any metal-to-metal connection should be secured with thread locker.
  one of the motors does not arm balabushka 4 113 01-Apr-2024, 09:54 PM
  Skystars 1404 motors (any kv) Pathfinder075 16 690 14-Mar-2024, 10:56 PM
  Solved 2004 3000kv motors on 6s Mad35 6 219 12-Mar-2024, 06:05 AM
Last Post: Mad35
  YSIDO MOTORS hawk01 2 536 16-Jan-2024, 06:14 AM
Last Post: hawk01
  ESC on AIO got silent and not spinning motors. Everything else looks fine. maxer 12 442 16-Dec-2023, 10:16 AM
Last Post: maxer
