Threads: 67
Likes Received: 713 in 473 posts
Likes Given: 1,216
23 Greetings all.....
I am getting ready to wire and mount my osd. I have looked all over the web and maybe I am just not looking in the right places or I'm too stupid to see the forest for the trees. Is there a good way to physically mount the micro osd, or is it even necessary? the thing is so small and light that maybe the tension from the wires is enough to secure it? Comments/Suggestions/Ridicule?? Thanks folks.
Threads: 17
Likes Received: 3 in 3 posts
5 My guess is that you should be fine if it is that small and light to let it "freehang" as long as you have it electrically isolated with heatshrink or tape to prevent accidental shorting.
I am a developing Racer - getting better.....
BNF Quads: <250 Eachine>; <250 Walkera Advanced CC3D>; <250 Vortex Pro>
Built:
Dronz Fury 252 RX ; Speed Addict 210-R
Building: <Deciding on Third build - Suggestions?>
Threads: 67
Likes Given: 1,216
23 That's kind of what I was thinking......it's like 15mm sq. and about 7g I think. Thanks for the response!.
Threads: 67
Likes Given: 1,216
23 Ok...so what I am hearing here is that there is no "standard" way to mount theses things...it's totally dependent on your particular build and whatever physical features you have available to use.....or not. I like the way Luc did it, but I am working with another type of PDB (ZMR) with the Overdraft board. Appreciate the input gents! : )
Threads: 67
Likes Given: 1,216
23 As best I can tell looking at mine it does not have a dedicated mounting area for the micro board. There is a way to mount the standard board UNDER the FC as I understand it, but the micro is only about a third the size of the standard board and wont fit. I'll ponder it a little more...thank you for your help.
Threads: 13
Likes Received: 10 in 8 posts
Likes Given: 9
3 Please share a picture of your board, i'll take a look then
My quad:
RD-210 / ZMX V3 2206 2140kv / Aikon SEFM 30A / X-Racer F303 V3 / X4R-SB / Dronelab 1500 4S 50C
Threads: 67
Likes Given: 1,216
23 pics of board attached
Threads: 67
Likes Given: 1,216
23 Look reasonable to me, but I am really new at this....seems to me that one ground from the osd to the central ground loop on the PDB would be sufficient? Thanks for you help! : )
Threads: 13
Likes Given: 9
3 Is this a 4S or 3S build? Are you using a 5V and/or 12V regulator? What voltage range do your camera and VTx need to operate? I'm just asking this, because perhaps we can make a complete drawing of your connections.
My quad:
Threads: 67
Likes Given: 1,216
23 Well. I wanted to make it both so I could use more aggressive props and not kill too much flight time, but everyone is telling me just to go 4S and be done with it. I think the camera is good with anything from 16 - 9 so it'll be ok with either....the VTX is good with 7 - 20 so it'll be ok too.
