Posts: 15 Threads: 3 Likes Received: 3 in 3 posts Likes Given: 0 Joined: Apr 2017 Reputation: 0 Hi I'm a newbie . I have a FuriBee F3 32-bit Brushed Flight Controller for flysky and i have a Fs-i6 transmitter. I had it working until i changed something in cleanflight and now when i turn it on the motors all run and my transmitter has no response any help would be appreciated Thanks Jim • Posts: 1,773 Threads: 30 Likes Received: 1,199 in 755 posts Likes Given: 714 Joined: Oct 2016 Reputation: 45 First off, what did you change? • Posts: 15 Threads: 3 Likes Received: 3 in 3 posts Likes Given: 0 Joined: Apr 2017 Reputation: 0 I changed a lot trying to fix it can't remember it all • Posts: 2,286 Threads: 38 Likes Received: 1,527 in 995 posts Likes Given: 1,881 Joined: Apr 2016 Reputation: 72 You need to set the motor pwm rate again. It thinks you have brushless motors. • Posts: 15 Threads: 3 Likes Received: 3 in 3 posts Likes Given: 0 Joined: Apr 2017 Reputation: 0 (02-Apr-2017, 12:01 AM)unseen Wrote: You need to set the motor pwm rate again. It thinks you have brushless motors. That worked do you think I have to re-flash it ? • Posts: 2,286 Threads: 38 Likes Received: 1,527 in 995 posts Likes Given: 1,881 Joined: Apr 2016 Reputation: 72 02-Apr-2017, 09:47 AM (This post was last modified: 02-Apr-2017, 09:55 AM by unseen.) (02-Apr-2017, 05:04 AM)jep4755 Wrote: That worked do you think I have to re-flash it ? Not if it's working now that you've set the PWM rate. If you don't see your receiver doing anything, then you need to configure Cleanflight to see your receiver again. As far as I understand, this flight controller has a built-in receiver that should appear if you set the receiver type to RX_PPM. It's always a good idea to save your configuration by doing a 'dump' command and copying the output to a file. That way, if you make a mistake, you can always get back to where you started. • Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 Also, a practice I use when tuning or changing anything, is to only change one thing at a time. This comes from my suspension tuning exexperience. Where if multiple componets are changed/tuned at the same time there's not a clear way to tell which is responsible for the improvement or decline in performance. I change one aspect then test. Then move on to the next. This practice has helped me in everything from RCs to sportscars to even the settings in how a video game performs. Hope this might help in future changes if you ever run into something like this again. Just my 2 cents Posts: 15 Threads: 3 Likes Received: 3 in 3 posts Likes Given: 0 Joined: Apr 2017 Reputation: 0 I got the motors to stop but now I can't bind to the board and I have no communication with my transmitter I can till communicate to he board with cleanflight but I'm lost i have flysky protocol I don't know how that relates in cleanflight . I think I might need to reflash not really sure how to do that any help would appericated Thanks Jim • Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 I dont know much about Flysky or cleanflight, but did you set the right Rx protocal on the configuration and ports tab? Just trying to help you brainstorm • Posts: 15 Threads: 3 Likes Received: 3 in 3 posts Likes Given: 0 Joined: Apr 2017 Reputation: 0 When I connect to clean flight it finds my board under ports Uart1 MSP 115200 on under receiver I have RX-PPM on for Fly Sky protocol and when I move my sticks they do respond on the screen and when I go to motors they respond in clean flight so i'm not sure if that means I'm binded but I cant get my transmitter to work or arm up I keep reading about end points and I'm not sure what thats about. Also not sure how to set the arming in clean flight . I'm about at the end of my rope any help would be appreciated Thanks Jim • Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 04-Apr-2017, 12:38 PM (This post was last modified: 04-Apr-2017, 02:50 PM by Drone0fPrey.) (04-Apr-2017, 06:28 AM)jep4755 Wrote: When I connect to clean flight it finds my board under ports Uart1 MSP 115200 on under receiver I have RX-PPM on for Fly Sky protocol and when I move my sticks they do respond on the screen and when I go to motors they respond in clean flight so i'm not sure if that means I'm binded but I cant get my transmitter to work or arm up I keep reading about end points and I'm not sure what thats about. Also not sure how to set the arming in clean flight . I'm about at the end of my rope any help would be appreciated Thanks Jim Hang in there! Im sure someone with more experience using flysky and cleanflight will come along to help. As for end-points, thats the full range of your stick inputs. Most times we need to tune our transmitters some so that the FC only sees a range of 1000 to 2000 and all but throttle centered at 1500. (Example: on cleanflight reciever tab when you push pitch stick all the way up, if it reads higher than 2000, adjust that channels endpoint on your Tx down until cleanflight shows 2000 on the dot. Same for stick full down, make sure that reads 1000 in CF. After that let go and dbl check pitch centers on 1500. If not tweak center point trims on Tx. Repeat for all channeTx) If everything is moving correctly in Rx tab and motors obey sticks on motor tab then Rx and FC are talking/bound . Arm swtich will probly have to be setup on your Tx first. Then find that channel on Rx tab (the one that moves when you change switch position) (note the range of values) and set Arming to activate when that switch is @ its top value. I hope that helps some. I got to go atm and like i said, im sure someone with more experience will be along soon to help also • Posts: 2,286 Threads: 38 Likes Received: 1,527 in 995 posts Likes Given: 1,881 Joined: Apr 2016 Reputation: 72 Gentlemen. The past tense of 'bind' is 'bound'. There is no such word as 'binded' in the English language! Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 Lmao it was early thx, and fixed Posts: 15 Threads: 3 Likes Received: 3 in 3 posts Likes Given: 0 Joined: Apr 2017 Reputation: 0 Doc1.docx (Size: 467.7 KB / Downloads: 96) Doc1.docx (Size: 467.7 KB / Downloads: 96) Every thing looks good but I can't get my transmitter to arm I put the arm on Aux 1 when I flip my A switch it go's up to 2000 and when I flip it back it's 1000 I dragged the sliders to each side of 2000 I don't have any other mode's setup do I need to setup a mode to make it work? I attached a word document maybe someone could take a look at my setting I know I attached it twice sorry about that. • Posts: 2,416 Threads: 51 Likes Received: 1,861 in 1,175 posts Likes Given: 3,315 Joined: Mar 2016 Reputation: 74 04-Apr-2017, 09:35 PM (This post was last modified: 04-Apr-2017, 09:38 PM by sloscotty.) You need to go into the modes tab and select Arm "Add Range". Select "Aux 1". Drag the sliders so that the little green position indicator falls within the range when the switch is in the position where you want it "Armed". If you've already done that, then you may have some issues with your throttle endpoints. Set the throttle endpoints in your transmitter to be 1000 - 2000. (Although it looks like you are pretty close if the 1004 is the actual reading when throttle is on.) • |
