Motor spinning wrong direction on Nighthawk Pro 280
I got a Nighthawk Pro 280 RTF and
Out of the box with preloaded Baseflight settings, besides the initial recommendations, first flight was flawless and quite a rush compared to my X5C-1 and MJX X600.
Without tampering with any hardware what so ever my M2 motor (CCW) is now spinning CW. How can this happen? Is it a setting in baseflight that I'm missing? Currently grounded.
i believe with the ESC firmware that comes with it, you can change ESC settings with your stick, you probably did it accidentally? you might have to google for a bit on how to do that
(12-Apr-2016, 11:52 PM)Oscar Wrote: i believe with the ESC firmware that comes with it, you can change ESC settings with your stick, you probably did it accidentally? you might have to google for a bit on how to do that
Thank you! back to the manual, remember seeing changes can be made with combined gimbal positions.
(12-Apr-2016, 11:58 PM)SonicCopter Wrote: Thank you! back to the manual, remember seeing changes can be made with combined gimbal positions.
my mate accidentally  change  his nighthawk280  motors to bidirectional  when trying to calibrate the esc,s  , i spent several hours  in cleanflight  trying to put them back to normal by using motor tab in cleanflight  one motor at a time  powering on at full throttle and sliding back down  till i found zero throttle   which was at about 3/4 on the slide bar  . i got it back to normal in the end but it was a nightmare .
 Maybe you should just change two of your motor wires round, this will change the direction  , any two will do  just pull out the white wire motor clip   and swap the wires round , ease the little tabs and the wires should just come out . or cut the wires and resolder . good luck bud
  Extra 4 PWM motor outputs dukevah 17 786 26-Feb-2023, 07:18 PM
Last Post: dukevah
  Help Mobula 6 Motor stuttering Shellodan 3 590 20-Jan-2023, 10:05 AM
Last Post: Shellodan
  High KV motor with 6s Pack and Throttle Limit thrasher7811 14 9,144 22-Aug-2022, 07:15 AM
Last Post: romangpro
  Does the uniformity or neatness of motor windings affect performance??? BigBeard 15 814 08-Mar-2022, 05:18 PM
Last Post: BigBeard
  Help Holybro ESC/motors stop spinning after about 10 seconds cpintheloop 7 987 23-Feb-2022, 01:04 AM
Last Post: cpintheloop
