Motor Spacers?
I need to mount the Multistar 2308's a little higher as the Trifecta (the Build:  http://intofpv.com/t-triple-treat-quantu...ecta-truck) arms don't give enough clearance for the motor shaft at the bottom.
Only needs to be 2-3mm lift.
Does anyone make such a thing?  I would use these https://hobbyking.com/en_us/carbon-fiber...-of-4.html but then I would be tempted to use 9" props which ill work with my motor and esc combo...  But well you know the drill - scope creep and all that.
So how would you resolve the problem?
Make a plate from some scrap carbon sheet or similar?
Use washers?
Use the extension plates anyway?
Builds: Mini-Quad  -  Tricopter
A Blog
How about cutting those in half and not extending? (buy two and have a spare)
Edit: Oops - see they come in sets of 4. That will give you a bunch of spares. Big Grin
Had a scurry in the carbon fibre bin at our workshop (where we do the car builds) and there's some nice 3mm offcuts that I can punch out with the holesaw and then tweak. Or just drop another bunch of money with hobbyking. *sigh*
A Blog
(26-Mar-2017, 12:11 PM)Aaron Wrote: Had a scurry in the carbon fibre bin at our workshop (where we do the car builds) and there's some nice 3mm offcuts that I can punch out with the holesaw and then tweak.  Or just drop another bunch of money with hobbyking.  *sigh*
I always get personal gratification from making something myself, from the "junk drawers" I have stowed around, as appossed to paying someone else for a product I'll probably end up tweaking anyway Wink
Just my 2 cents, but if it's anything like the work youve done for that Belkin kit car, I say make it Wink (been following your Other Things We Do thread)
On a side note. I'd be curious to see if someone were to softmount those extensions with anti-vibe tape or similar. Could have different effects than traditional/current softmounting, no?
The Obsession IS Real!
2-4mm rubber from the local department store?
I hadn't thought of that (rubber) - as it happens we have some trim seals I could use. Would be more challenging to work with because over tightening would still pull the motor shaft into the cups on the arm.
Will do some thinking.
A Blog
Question Help Diatone MXC Taycon Cinewhoop's 4th motor isn't working rr240 1 39 23-Apr-2024, 10:09 PM
Last Post: mstc
Question Help Diatone MXC Taycon Cinewhoop's 4th motor isn't working rr240 0 37 23-Apr-2024, 09:36 PM
Last Post: rr240
  Sometimes a motor surprises you - in a good way mstc 20 780 10-Apr-2024, 09:00 PM
Last Post: mstc
  Help Brother Hobby Motor VY1507 hawk01 3 92 05-Apr-2024, 07:58 AM
  Help Mobula 8 after crash motor ramp up to max with minimum throttle johnny1234 7 938 31-Mar-2024, 05:43 AM
Last Post: spiralthomas
