motor smoked and worked fine?
Just put dys 4000kv motors on my 3" shrieker and did a throttle calibration, and the motors gave me smoke! Was like wtf!
After smoking it's to late to do anything so went on with finishing and did a test hover she flies fine so? I don't know if anyone else ever had this happen? Would this do anything bad to the motors?
Dys esc? I had this happen also. Had my buddy change a setting in blheli and it fixed it. He said the volume for the beep was to high heating the windings up.
I think it might be The volume on your ESC beeping in blheli was turned up all the way!
Set beacon delay to infinite
[-] The following 1 user Likes DragonFly's post:
  • Multirotor Army
I have had this happen on many different motors, DYS, EMAX, Xnovas, not all the time, I do a calibration and while it is going through it's paces what appears to be smoke comes from 1 sometime 2 motors, First thoughts are you have killed a motor, But like the OP, I finish up and the motors run fine.
My thoughts on this, and could be way off the mark here.
During the building of the motors at the factory they have have used some form of lube that has a bit of residue on the windings, and it is that residue just smoking when power is attached. No idea if I am right or not.
My youtube channel
  Sometimes a motor surprises you - in a good way mstc 20 758 10-Apr-2024, 09:00 PM
Last Post: mstc
  Help Brother Hobby Motor VY1507 hawk01 3 84 05-Apr-2024, 07:58 AM
  Help Mobula 8 after crash motor ramp up to max with minimum throttle johnny1234 7 877 31-Mar-2024, 05:43 AM
Last Post: spiralthomas
  PWM circuit for a motor testing rig Pathfinder075 10 175 28-Mar-2024, 04:44 AM
Last Post: skywanderer
  Recursion Labs - Sub 250g Motor and Propeller Testing Recursion 36 4,935 21-Mar-2024, 07:02 PM
